Heater unit
Started by frank1966, January 08, 2021, 09:23:33 PM
frank1966
Hello,
What do the 2 tubes at the bottom of the heat unit do? Iam reinstalling mine and having a hard time getting one of these tubes to fit through the firewall
70 sublime
Condensation water drip out so it does not leak inside the car interior
frank1966
Thanks, i am having a very hard time getting it in on drivers side. I got in everything in on the passenger side
GreenMachine
The one on the left connects to the fan motor with a 90° hose. I think it's to keep the motor cool. The one on the right is a condensation drain for the evaporator.
70 sublime
Quote from: GreenMachine on January 09, 2021, 11:32:28 PM
There are 3 pipes coming out of the back
Yes the one beside the big hole goes to the electric fan motor with a rubber elbow and the lower over 2 are drains
frank1966
Thanks, related question, does it matter which port I use on vacuum canister ? Is there an orientation? Ports on can are the same size
