water pump
Started by flyinlow, March 24, 2021, 09:40:10 PM
flyinlow
Anyone use a Flowkooler water pump on a RB?         https://www.manciniracing.com/flhimewapu.html
AFD 792
I built a 500ci stroker with Flowkooler and a high flow thermostat that ran hot. Changed to a factory pump and thermostat, temps dropped.
68CoronetRT
I run a Summit brand water pump housing, Flowkooler pump and Milodan hi flow 180 t stat. In 100 degree ambient at idle the car might see 195 and as soon as I start moving it drops to 175-180 or so. In the winter it sits about 160-170 or so. Aluminum 2 row radiator with big tubes and a clutch fan from a Jeep.
The real key to cooling these engines is the water pump housing, radiator and having a fan shroud. IMO
gsmopar
Don't forget the bypass modification:
IMG_2288 by Greg Ault, on Flickr
flyinlow
Challenger340
We use these lots.... never had an issue.
ProForm 440-452 Aluminum High Flow Water Pump $82.99
https://www.summitracing.com/parts/pro-440-452
ProForm 440-453 Aluminum Water Pump Housing $127.99
https://www.summitracing.com/parts/pro-440-453
Only wimps wear Bowties !
Kern Dog
flyinlow
Thanks for the reply's.
flyinlow
Quote from: Challenger340 on April 07, 2021, 05:38:08 PM
With the Proform pump are you using the smaller A/C size pulley?
Challenger340
Quote from: flyinlow on April 08, 2021, 10:56:26 PM
I am not sure what pulley many are using for their Final installs ? I know many do run A/C though.... and I've heard no negative feedback to report.
