ID these parts
Started by C500, April 10, 2021, 08:20:51 PM
C500
Hey guys, anyone know what these 2 bits are off?
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
70 sublime
its the end clip thingy for the door belt mouldings , there i one each side , see pictures below & green arrow.
your second picture ! dont think its off a second generation , although it kind of looks like the inner door panel & rear quarter stainless trim divider between upper pad & lower  , hard to tell from the picture , any chance of a better picture ??
C500
C500
Hey guys, next question.. what is this little guy for? Sits in sail panel, but not to locate a headliner bow...
70 sublime
Think there is 2 short head liner bow type of rods on either side of the car by the back window and that is how it hooks into the roof frame
C500
Quote from: 70 sublime on April 15, 2021, 10:28:27 PM
Hmmm, ok, not sure I have it/them.... same thickness as the main bows? Any pics?
cdr
Quote from: C500 on April 15, 2021, 10:40:58 PM
The c500 might not use those, ????
C500
Quote from: cdr on April 15, 2021, 10:59:18 PM
Yeah, maybe you're right... on a regular charger or R/T, is there supposed to be 4 of those clips- 2 each side? And with a pair of short rods/bows (1 each side) ?
70 sublime
I have never had an areo car back window before but I would think they still would use the same parts as a regular Charger head liner in this area because the added back window is farther back and the new head liner still needs to be supported in the same places before it is pulled through the regular Charger window hole to reach the new back window space
Some pictures I found on the web
Second picture shows a wire
There are two of these one on each side and they hook on the most rear head liner bow so when you pull the head liner forward to stretch it this is what it is pulling on to keep it tight
C500
Thanks for the replies and pics  :cheers:
