Ballast resistor
Started by C500, April 18, 2021, 07:10:30 PM
C500
guys... I have a new coil and dizzy from firecore, Hi-rev electronic ignition module....wondering what size Ballast resistor I should be using / and is the size very important ie 0.8 ohms... 1.2 ohms etc?
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
