Brake Fluid
Started by Danacus, July 08, 2021, 06:42:25 PM
Danacus
I bought a '69 Charger that has a Hydraboost base model on it that uses a Mopar spec master cylinder. The pedal has been a little low and I could sometimes hear some noise it the fluid system. Now the brake light on the dash came on. I assume that I need to add some fluid (not sure where its leaking from). What brake fluid should I be using?
Thanks,
Dana
That light comes on if the emergency brake is down even just a bit so 1st be sure that it is fully up by pulling the release and lifting up on the E. brake. The other reason that light will come on is an imbalance between front and rear brakes.
Look for leaks. Find out what kind of fluid is in the system and add more of the same.  :scratchchin:
