Coil over shocks
Started by Mr. Lee, August 19, 2021, 11:55:14 AM
Mr. Lee
Hi guys, does anybody know if there are adjustable coil over shocks out there that fit the original rear of a 69 Charger. I now have Monroe coil overs but I don't like the look of the car now, is a bit to high on the rear. If I have adjustable ones I can lower the rear just the way I like it. Thanks.
Serge
Kern Dog
The shock crossmember was never designed to support the weight of the car, it was meant to support the shock absorbers and their function. Coil over shocks are a crutch for weak leaf springs.
Mr. Lee
Quote from: Kern Dog on August 19, 2021, 11:44:58 PM
Hi, I know my leaf springs are weak, they will be repaired. Still want coil overs also.
ACUDANUT
 You can also add a reinforced bracket to the shock towers.
cdr
Quote from: Mr. Lee on August 23, 2021, 01:54:49 PM
Just get some MONROE air shocks & keep the PSI under 55 [ Calling all the naysayers]
