440 Timing issue?
Started by JPL, November 15, 2021, 09:20:29 AM
JPL
Hi all, I have a '71 Charger with a 440, .30 over, 906 heads, 268/454 comp cam, Holley 750 vac sec, electric fuel pump, 2800 stall converter, 4:30 gears. The issue is, when the car is warmed up, in gear, from idle, I push the gas pedal down about half way real quick and lift, the car will launch forward nicely, then it stalls. I can't time it with a timing gun because the tab on the timing cover is way off for some reason, I think it's from another motor during the rebuild. So, do you guys think this is a timing issue? If so, should it be advanced or retarted?
Thanks!
70 sublime
Does it have vacuum advance on distributor ?
JPL
Quote from: 70 sublime on November 15, 2021, 02:20:23 PM
Yes, MP electronic ignition.
cdr
you need to get the timing mark correct !!!!!
INTMD8
Quote from: cdr on November 15, 2021, 10:58:23 PM
Yes agreed.  "should it be advanced or retarded from unknown position" =  :brickwall:
Best would be use a piston stop, one way mark dampener, other way mark dampener, halfway inbetween is your TDC.
Could ballpark it with a straight piece of wire/coat hanger through the spark plug hole (and draw gradient lines on it with a marker so you can see relative movement)
JPL
Quote from: INTMD8 on November 18, 2021, 01:27:25 PM
The question isn't "should it be advanced or retarded from unknown position"
The question is "when the car is warmed up, in gear, from idle, I push the gas pedal down about half way real quick and lift, the car will launch forward nicely, then it stalls...... So, do you guys think this is a timing issue? If so, should it be advanced or retarted?"
The cars runs great and it pulls strong, the stall after a throttle blip is the only issue.
INTMD8
^ If you don't know what the timing is, that is exactly the question.
JPL
Just want to know, if the car is stalling in that situation, are the chances more likely that the timing needs to be advanced or retarted..........
INTMD8
No one could possibly have an idea.  It needs to be done correctly. May have nothing to do with timing but step one is correct the timing mark and actually set the timing.
JPL
Quote from: INTMD8 on November 20, 2021, 12:59:23 PM
4 experts/mechanics have an idea, they all said timing but 2 said advance and two said retard, lol. It runs great, (through power timing), except for that issue and with out proper timing marks I didn't want to screw it up further, so just was looking for opinion/direction.
INTMD8
Quote from: JPL on November 20, 2021, 03:07:17 PM
Ok, do it right.  Or just randomly move the distributor around  :lol:
Trying to tune this to run correctly is just a complete waste of time otherwise but good luck with it.
BSB67
11.68 @ 120.2 mph
69hemibeep
Quote from: JPL on November 15, 2021, 09:20:29 AM
Don't do this  :lol:
AKcharger
JPL you have to go step by step on this stuff...and step #1 is find where timing is now as detailed above
metallicareload99
Quote from: JPL on November 19, 2021, 12:11:12 PM
...I push the gas pedal down about half way real quick and lift, the car will launch forward nicely, then it stalls...... So, do you guys think this is a timing issue? If so, should it be advanced or retarted?"
Does it stall completely as in engine off? Not trying to pile on, but I don't really see the point of such a "maneuver?" If easing off instead of lifting quickly does it not stall? At any rate, in my nonexpert opinion, this suggests carb tuning is needed if anything :shruggy:  No timing pointer isn't a problem per se, I drove around for years with no pointer, but you'd have to put in some effort tuning it still
Closet Mooar guy
