Fuel pressure:
Started by Captain D, March 28, 2022, 02:05:08 PM
Captain D
Hi,
Just curious if anyone here runs with these fuel pressure regulators with gauge. If so, any pros/cons:
https://fitechefi.com/product/54002-dual-output-fuel-pressure-regulator-gauge-fittings/
Granted, I realize that the inline gauge is a plus, but is it worth the extra $$ compared to, say, the standard regulator:
https://www.summitracing.com/parts/bch-0280160575
The Fi-Tech indicates that you can adjust the fuel pressure from 30psi and up. But, for EFI, it may not be needed (or best) to go that low anyway.
Thank you for any feedback...
metallicareload99
Are you running fuel injection? And if so do you think you have a fuel delivery issue? FiTech has an internal regulator and displays fuel flow, I would think you could get a good idea from that :shruggy: Otherwise there are stand alone fuel pressure gauges
Captain D
Thanks for your reply. Yes, I have EFI, but was losing fuel pressure at incline at the close of last season. That's why I gravitated towards a possible fuel pressure regulator as a point of entry into this project.
I was thinking about the stand alone fuel pressure gauges too (in conjunction with the Bosch brand) to see where that may lead...
