DodgeCharger.com Forum
August 07, 2022, 04:21:56 PM *
News: DodgeCharger.com decals are available here!
   Home   Help Calendar Login Register Chat
Pages: [1]   Go Down
  Print
Author Topic: Back glass clips  (Read 247 times)
C500
Old Timer
Offline Offline
69 C500 New Zealand
« on: May 22, 2022, 11:00:50 PM »
Hi… does anyone know where these clips attach for back glass? And is there supposed to be only 2?
Logged
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
RTSE440
Junior Member
Offline Offline
« Reply #1 on: May 23, 2022, 02:40:56 AM »
I think they are the clips that hold the glass at the correct height off the bottom channel when you fit the window
Logged
C500
Old Timer
Offline Offline
69 C500 New Zealand
« Reply #2 on: May 23, 2022, 06:12:23 PM »
Ok, so 2 clips is correct... and both go on bottom?
Logged
Hemidog
Old Timer
Offline Offline
'68 Charger 451/727/8.75
« Reply #3 on: May 23, 2022, 11:29:14 PM »
They look like pic 2 in this thread:
http://www.dodgecharger.com/forum/index.php/topic,48725.1200.html
If you look closely on picture 1, it looks like they go on the original back glass location, on the bottom.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.043 seconds with 17 queries.
