70 R/T SE
Started by doctor4766, June 02, 2022, 08:35:05 PM
doctor4766
Quote from: 6bblgt on June 14, 2022, 02:34:51 AM
X25 could be as simple as the factory headlight aim set-up slight SHIFT to the left for an original destination to a LH drive country
what's the earliest known country & during what year?
is the high-beam indicator on the dash always on?  the all 4 lights on sounds like a switch or wiring problem
It appears that both sets of lights are high/low beam type lamps and they all do both.
Perhaps this is the difference between the export model as I don't see how the lights could momentarily dip to the left as suggested earlier.
The high beam indicator is only lit when high beam is selected.
Gotta love a '69
doctor4766
Quote from: 426HemiChick on June 14, 2022, 11:42:51 AM
Quote from: 6bblgt on June 14, 2022, 03:45:35 AM
1970 EXPORT order E91160 is/was in Argentina
both Peru & Argentina drive on the RIGHT  :scratchchin:
Hi Doctor4766,             14 June 2022
That's a fine looking 70 Charger. Based on the underside, the car appears to have lived its life in a very dry climate. Good luck with the restoration.
Having lived in and driven in countries that drive on the left and right, still to this day there are times when I turn a corner, with no cars in sight, I'll sometimes find myself driving on the left. It doesn't occur as often as it did when fresh back from a left drive country. Both seem normal to me. My last was Singapore and Kuala Lumpur 1997.
I have enjoyed all the places I have lived and worked. Never made it to Australia or New Zealand. Came close a couple times. Came close to emigrating to Australia in 1968; a 68 Hemi Road Runner interfered.
The rest is history. Happy to finally be home with Dena here in Phoenix. It's been a long road.
Best Always
Christine for the 426 Hemi Chicks
Whilst I jump from my LHD to RHD cars without even thinking about it these days, I've never driven on roads made for LHD other than 1 time in Dubai, when one of my nephews who lives and works there wanted to test drive a Challenger.
We went to the dealership and took an SR/T8 for spin.  :2thumbs:
Gotta love a '69
doctor4766
The brakes were feeling a little soft and I could hear vacuum down in the footwell as I depressed the pedal so I decided it would be a good idea to remove the booster and take it in to have it checked out  :brickwall:
Man, what a job it was getting to 2 of the booster retaining nuts under the dash.
I ended up pulling the driver's seat so I could half see what I was doing, lying on my back.
The location of the 2 nuts on the RH side of the column is such that no matter which spanner or socket I used there was always something fowling and it made it hugely awkward to do.
Eventually, like about 90 minutes later I managed to get that last nut off by slipping my hand into a gap that I had no idea if I'd be able to get back out of. (Picture Homer Simpson with hand up vending machine)
Surely there's a easier way?
The FSM says in the booster removal procedure, point 4 - From under the instrument panel remove 4 brake unit attaching nuts and washers  :smilielol:
I left the booster at the brake specialists and should hear back today whether it's serviceable.
Not really looking forward to the refit....
Gotta love a '69
doctor4766
Meanwhile, I have decoded the build sheet based on information on the 1970 Dodge Charger Registry.
Interesting that some items you would expect to be standard, such as ash trays,carpet and belt moldings.Even the Oil Pressure Gauge?
A01   LIGHT PACKAGE
A47   SE PACKAGE
B41   DISK BRAKES
B51   POWER BOOSTER
C21   BUDDY SEAT
C23   REAR ARM RESTS WITH ASH TRAY
C55   BUCKET SEATS
C62   ADJUSTABLE DRIVERS SEAT
C93   CARPETS
F25   HD BATTERY
F96   OIL PRESSURE GAUGE
G11   TINTED GLASS
G31   RH MIRROR MANUAL
G33   LH REMOTE MIRROR
G41   PRISMATIC REAR VIEW MIRROR
H51   AIRCONDITIONING
H31   REAR DEFOGGER
J11   GLOVE BOX LOCK
J15   CIGARETTE LIGHTER
J25   3 SPEED WIPERS
J31   DUAL HORNS
J41   PEDAL DRESS UP
J46   LOCKING GAS CAP
J55   UNDERCOATING WITH HOOD PAD
J64   WOODGRAIN INSTRUMENT PANEL
L05   MAP/COURTESY LAMP
L11   GLOVE BOX LIGHT
L15   ASHTRAY LIGHT
L25   TRUNK LIGHT
L31   HOOD TURN SIGNALS
L65   LIGHT IGNITION TIME DELAY
L72   HEADLAMP ON BUZZER
M05   DOOR PROTECTION MOLDING
M21   DRIPRAIL MOLDINGS
M25   SILL MOLDINGS
M31   BODY BELT MOLDINGS
M81   FRONT BUMPER GUARDS
M83   REAR BUMPER GUARDS
M91   LUGGAGE RACK
N41   DUAL EXHAUST
N85   TIC TOC TACH
N88   AUTO SPEED CONT (CRUISE CONT)
P31   POWER WINDOWS
S15   RALLY HD SUSPENSION F/R
S25   HD SHOCKS
S31   FRONT SWAY BAR
S77   POWER STEERING
S81   SPORT STEERING WHEEL
W21   RALLYE WHEELS
X25   LT BEAM SHIFT
X66   MFG FOR EXPORT LABEL
Gotta love a '69
hemi-hampton
About the only option your missing is Power Sunroof. Can't believe it's not a 2 tag car. LEON.
doctor4766
Quote from: hemi-hampton on June 15, 2022, 11:09:19 PM
No radio option ticked on the build sheet though.
Perhaps that's why there's no antenna hole on the fender
Gotta love a '69
Alaskan_TA
No radio was standard, all radio options were extra cost.
So with no radio, you got the blank plate on the dash.
A rubber plug would have gone in the passenger side panel vs. the plug for an antenna cable.
No center dash speaker either, so a black cardboard type material in it's spot to block off the speaker grille in the top of the dash frame.
No radio = no antenna, thus no hole in the fender for one.
doctor4766
So my question now is whether there is an easier way to bolt the booster back in.
Do people drop the column for access the studs?
Gotta love a '69
66FBCharger
I usually remove the gauge cluster and work through where the gauge cluster was. I use a long swivel extension and maybe a universal joint to reach the nuts. It makes it a lot easier, though its a little work to remove the gauge cluster.
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
Alaskan_TA
Under dash work is not my favorite, but I was able to remove & reinstall mine with the column, cluster & everything else under the dash in place.
472 R/T SE
I needed help to replace my booster in AllBlueRT.  Then again I was recently paralyzed back then, lol.
Pretty sure we dropped my column.  It was a PITA tho!
Hate asking for help, lol.
doctor4766
Thanks gents.
I much prefer the idea of not having to remove the cluster or steering column,
Perhaps I'll give it a shot crawling under the dash first.
Gotta love a '69
472 R/T SE
doctor4766
Quote from: 472 R/T SE on July 09, 2022, 08:14:13 PM
Whats the latest?
I sold my 69 and it actually just went on Saturday :(
I bought that car as a project in 2006 so I was sorry to see it go.
Had the buyer not been able to get the deal done with his bank I may have in fact kept it and sold the 70 instead.
Not that there was any real reason to not want the 70, just the attachment I suppose.
Anyway, I had the booster and master cylinder rebuilt by a local specialist and set to refitting them.
Despite not dropping the column and it feeling like my hands had grown since the removal, I managed to get it all bolted back up in place and with the help of my wife, we bled the brakes.
They are feeling much better now and stop the car better than the brakes ever did on the 69 but I have yet to pull the drums and calipers to do a proper check on their condition.
My initial plan is to get the car running and driving properly with everything working as it should, especially the cooling system and aircon.
We get some pretty hot days here (3-4 days of 42/43*c in a row this summer) so finally having a Charger A/C will be a real treat.
Gotta love a '69
472 R/T SE
I hear ya on the heat.  I've moved back to my home town area and I guess I forgot about the heat.  Altho all the old timers are saying somethings wrong.
Forecast is over 100 for like 12 days in a row.  Only cause thats all the further out the forecast goes, smh.
Move back home Mike, be close to your still non existent family they said, lol.
doctor4766
The previous owner had this car for 40 years and put it in for painting in South Africa, prior to emigrating here, to Perth in Western Australia.
They shipped it after he had already moved here. He told me that he had never been happy with the job that had been done and that the Candy red wasn't as Candy as he was expecting, but by this time it was too late and he couldn't send the car back.
The leaded area where the roof meets the quarter panel was beginning to bubble out due to some reaction and looked quite unsightly.
My first thought was to have the areas repaired on both sides of the car and have the paint "touched up" but the body shop said that they wouldn't be able to match the paint and I should look to repainting to whole car.
This wasn't an option for me at this stage as I have sold the '69 and didn't want to have the car off the road for however long that might take to do properly. So I made a decision to have the roof repaired and to fit a vinyl top.
I know this car didn't come with one but it's not like they never did and that it can't be removed should I ever do a full restoration, right?
Gotta love a '69
hemi-hampton
Previous owner said not Candy enough? maybe it never was Candy, maybe just a metallic Red? :scratchchin: :shruggy: It's hard to match any Candy if you don't know what base was used under it & how many coats applied but it can be done or come close, I've done it many times. I'd rather have a mismatched paint spot then the vinyl top added but just my opinion. :Twocents: :scratchchin: :shruggy: :slap: LEON.
P.S. If it is Candy maybe they used the newer Candy. Which would be red used over a red base, which don't give you the more intense Candy look of the old days when it was sprayed over silver or gold :shruggy:
AKcharger
The car was in Rhodesia!!!! THAT IS COOL
Anyway you have photos of it's time in Africa??
doctor4766
Quote from: hemi-hampton on January 08, 2023, 10:03:12 AM
Yes, you make some good points there.
The areas that needed work would have been very unsightly to just leave, so until I'm ready for a full resto I'll drive it as it now stands.
I have some pics that I'm in the process of getting ready to post so stand by...
Gotta love a '69
doctor4766
Quote from: AKcharger on January 09, 2023, 06:36:57 PM
I don't at this point in time sorry.
Gotta love a '69
AKcharger
Quote from: doctor4766 on January 09, 2023, 06:47:44 PM
doctor4766
I think she turned out nicely
Gotta love a '69
AKcharger
Quote from: doctor4766 on January 09, 2023, 10:26:33 PM
Red with black vinyl top is the ULTIMATE color combo
Kern Dog
I like a bald roof......
doctor4766
Quote from: AKcharger on January 10, 2023, 06:55:25 AM
I really like it too.
It just breaks all that red up.
Quote from: Kern Dog on January 10, 2023, 02:54:52 PM
I may have even left it alone had there not been those bubbles over the leaded area
Gotta love a '69
