bench test amp gauge
Started by r4daytona, June 05, 2022, 12:33:04 PM
r4daytona
I have my cluster out of my car because of electrical problem I'm trying to figure out.
How to i bench test my AMP gauge to make sure it's working properly?  Please explain it in laymans terms because I suck at electrical.  Post pictures of how if you feel it may help.  Thank You
birdsandbees
Battery and a head light bulb. Run one wire from battery to bulb directly and the other one through the amp meter.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Quote from: birdsandbees on June 05, 2022, 05:09:16 PM
might take more than one headlight to make a significant needle movement on the ammeter gauge
birdsandbees
Quote from: A383Wing on June 05, 2022, 06:36:01 PM
Turn you headlights on without starting the car... see how much that needle moves!
Jus in case... if headlights are relay feeded from the batt, the needle won't move
