accurate exhaust
Started by RTSE440, June 07, 2022, 03:30:54 AM
RTSE440
Hello all thinking of purchasing an exhaust system from Accurate Exhausts just wondering how good they fit and how do they sound as they have 2 options one as hi flow hemi style mufflers and 2nd option Magnum mufflers has anyone used their exhaust systems and which mufflers did you buy how good do they sound maybe you have a YouTube video i can see thanks ahead guys looking forward to some reply's
Don't they use 14GA. tubing? Much better than others.  :scratchchin:
I've had an Accurate Exhaust on my Charger for about 20 years now with zero issues.    Had the Hemi High flow mufflers on there for a while.
These are all with stock HP cast iron exhaust manifolds
https://youtu.be/BoL7KfJsI-E
Later switched to the Ultra-Flo's by Dynomax
https://youtu.be/0zMt_kCMSZA
Another Ultraflow idle one
https://youtu.be/93ODp-tYAbw
RTSE440
Quote from: Just 6T9 CHGR on June 09, 2022, 04:29:13 AM
Thanks for your reply good to hear zero issues with the system the Hemi hi flow sound a lot angrier & the ultra flo's have a bit more drone too them.Which one did you prefer ?
kept the Ultraflos.   zero drone
gtx6970
Good videos Chris
I want to get the Satellite a little more rumble. and have been leaning towards the UltraFlows. You sold me
I wonder how much difference there is in sound
from the Ultra Flows to these
https://www.summitracing.com/search/brand/dynomax-performance/part-type/mufflers/make/plymouth/engine-size/7-2l-440/engine-family/mopar-big-block-rb/case-exterior-length-in/20-00?SortBy=Default&SortOrder=Ascending
metallicareload99
Quote from: Just 6T9 CHGR on June 10, 2022, 04:32:01 AM
:iagree: My SuperTurbos had a pretty bad drone at a certain RPM, UltraFlos -> no drone. Definitely more rumble, but I was pleasantly surprised that it wasn't too much. I used the same tti exhaust from the x-pipe back on essentially four different 440's, and the engine build itself made by far the biggest difference. Stock based non-HP 440 was pretty mild with SuperTurbos but there was the drone I mentioned. Same 440 with Ultra Flows was more rumble and seemed a little deeper. Same exhaust with smog 440 was very mild, almost too quiet. I apparently offended a lady at how quiet it was idling at a stoplight. Rebuilt 0.030" over 440 with aluminum heads, solid roller cam and 10.2:1 compression is loud all the time, to the point I'm sure all my neighbors hate me :drive:
Old video, stock nonHP 440:
https://www.youtube.com/watch?v=QEs27PNHt-c
