Glove box locked
Started by grdprx, August 06, 2022, 03:53:44 PM
grdprx
I locked my glove box a few years ago, I was curious if the key matched.  It worked, I locked and unlocked it a couple times; then I couldn't get it to unlock.  It's been that way ever since, every time I get in the car, I try and unlock it, but no luck.  Does anyone have a suggestion on how to unlock it?  Should I just try graphite or a dry lubricant, or has anyone else figured anything out with these old cars?  I don't want to break anything, but it'd be nice to be able to use the glove box.
70 sublime
grdprx
  when you locked it & un locked  it a couple of times  to test the key ,  was the glove box closed or open when you tried the key ?
does the key turn in the lock or .... ?
  http://www.dodgecharger.com/forum/index.php/topic,109484.0.html
histoy
My glovebox lock wouldn't open again yesterday.  It's happened before, and I've given it a shot of graphite, which helps for a while.  I have a can of WD40 that has a small red tube attached to the spray head.  I inserted it into the key slot and gave it a small squirt.  Then I inserted the key and worked it in and out.  The lock opened, but still didn't work smoothly.  With the glovebox open I pushed in on the small latch on the lock and gave it a small squirt of WD40.  I reinserted the key and worked the lock open and closed several times until it worked smoothly.  I know that graphite is recommended, but my lock is working well now.  Hopefully it will continue that way.
grdprx
The glove box was closed when I was cycling the key.  It no longer turns.
I'll get some graphite, and try that. I was a little wary of WD-40 because it's not recommended for locks as it can attract dust.
Gold Rush
Pick up a can of Liquid Wrench spray silicone.  It does not attract dust and is an excellent lubricant.
24 years USAF, 25 years consumer electronics repair technician.  Now I ride a Honda Goldwing trike and wrench my latest project.  Children and Grandchildren are gown so I have to find other places to spend my time and money!
Quote from: grdprx on August 09, 2022, 07:13:38 AM
oh right closed,
just for curiosity sake i would  try  with fingers or carefully with  a sutible tool  try levering a little  or rocking by putting something under the bottem edge of the glove box door & dash frame  ( dont know the correct word for this action should be  :slap: :lol:  / pressing door  in & out \a little while opperating the key ,  i'm not very good at explaining this  .......anyway its  like you would to test to see if any door is locked etc but turning a key gently at same time ,
the glove box latch/ striker on dash frame might be out of adjustment  ... to far in or out putting pressure on lock so difficult / wont turn ...... just an idea  :scratchchin:  after ive typed all this prolly  seized & just wants some lubrication  :lol:
grdprx
Thank you tan top!  I wasn't able to cycle the lock, but the door did pop open,  I can now fix or replace the lock/latch.
Which way is the key supposed to turn to unlock?   Also, is the button supposed to be compressed while locked?  Wondering it the assembly failed.
Quote from: grdprx on August 10, 2022, 06:48:53 PM
:cheers:
thats good you got it open  :yesnod: :2thumbs:
the button stays out all the time,
just press it in to open door,
to lock glove box turn key clockwise to 3 oclock,
to unlock counter clockwise ,  & the key returns to the 12 oclock position ,
what type of latch / striker have you got on the dash frame ?  is it the cast base & spring loaded bar  or bent wire  type ?
grdprx
I'm guessing this is the bent wire type?
I found another button/lock assembly that matches my key, thanks for your help.
Quote from: grdprx on August 12, 2022, 05:30:02 PM
thatsa good you got it sorted  :2thumbs: :cheers:
yes wire type,
not sure if i'm remembering this correctally but think the bent wire type was the  superseded part to replace the  cast base spring loaded bar type , see picture below , to stop the glove box popping open at random times by its self , i might have this round the wrong way though :shruggy:
