Superbird stuff needed
Started by Impkidd, August 26, 2022, 05:54:35 PM
Impkidd
Starting to restore the disassembled Superbird, and some items are needed. Other items may be needed as the job goes. These are the part numbers that I know of for each item. Would you have any spares to part with?
   -NOS antenna mast, telescoping 60" #2889919
   -NOS outer driver door handle #3454391
   -NOS "Road Runner" trunk lid emblems, 'long pin' type, casting & part #'s 2964114-5
   -NOS or excellent used, 'Coronet' side marker light assemblies #3403774-5
   -'Coronet' side marker, inner retainer brackets #3403784-5
   -New or used, original trunk lid weather strip, with embossed part number "2482852". Book #3445379
   -Nose cone front rub strip (new - 'nice' used?) #3571174
   -NOS Westinghouse headlamps 4001 & 4002, Safe T Beam 12V  '8-9' area date code.
   -NOS rally wheel center caps, #3461066
   -Rear U joint, large 7290, casting "2781937" & "DETROIT", with strap?  Book #2781923?
   -(3) 14" x 5.5" rally rims. I have one nice dated '10-31-69'. Part #2944252 at valve stem. Want to make a set of four of the same date. What wheel date codes do you have close?
   -(1) 14" x 6" black steel spare rim, #3420978. Date code mid November and back?
   -Excellent original rally dash pad top?
   -(2) Lower, small rear hood bumpers, with part # "PA 1943547 DPCD" embossed on them.
   There may be more items needed in the future. I'll list as needed. PM me. Thanks, Rob.
Impkidd
