wet sanding
Started by 69bananabeast, August 23, 2005, 11:13:11 PM
69bananabeast
getting the car prepped for paint , and was wondering is  220 grit not fine enough ?
1969 Charger  446
1970 Charger  318
1932 Ford Rat Rod   (under construction)
Drop Top
What are you doing? Blocking the primer? Or Color Sanding the paint for buffing?
Paint Reps recommend no finer then 400 wet or 320 dry for final sanding, before painting.
I block my cars with 180, reprime, then 220, reprime, then finish with 400. Seal then base then clear.
69bananabeast
Got all the body work for my car done , and a friend told me to wet sand car with 320
1969 Charger  446
1970 Charger  318
Drop Top
320 wet might be too course of paper to try and cover with the paint. Like I mentioned before. I use 400 wet for my finial sanding. 360 wet would be as course as I would go. Otherwise you will be putting on an extra layer of paint to cover the scratches.
cudaken
 On quickey spot job's have used 320, but the good stuff I would go with 400 as well.
                                           Cuda Ken
I am back
beenaround
good advice guys!people pay attension
69bananabeast
1969 Charger  446
1970 Charger  318
