MoparStuart's Convertible Superbird Project Pic's
Started by MOPARHOUND!, August 17, 2007, 01:29:18 PM
moparstuart
Quote from: hotrod98 on July 15, 2010, 02:07:24 PM
I bought a set of rods from Mopar Performance a few years ago for the six pack motor in the 69. My son worked for a Dodge dealership and they let him order 12 rods. We picked out the ones that were closest balance wise and sent the other four back. My machine shop was able to get that rotating assembly perfectly balanced. You can really tell the difference when they're balanced correctly. They live a lot longer too. I'm not sure if they still make those rods but they were similar to the six pack rods. I have a set of six pack rods but they're not close enough in weight to get a real good balance. If you want them I'll take a $100 for the set. You might pick up a couple of more rods somewhere and make a close set. I've been saving them for a guy but after six years I'm beginning to think he doesn't want them.
I've been running Manley rods in most of my race motors, I've had very good luck with them. The little super pro small block motor sees 6800 quite regularly. I run aluminum rods but I think they make steel rods as well.
thanks for the offer on the six pacs but i want new rods and i want someting lighter then those monsters , they were in the first motor and  I put one out the side of the block .
BigBlockSam
Quotethose monsters , they were in the first motor and  I put one out the side of the block .
Yea , those sixpack rods are to heavy . now they got stronger ones that are lighter.
moparstuart
Charger-Bodie
Stu, Those are an excellent choice for connecting rods.  :2thumbs:
moparstuart
Quote from: 1HotDaytona on July 16, 2010, 08:59:50 PM
cool  I think i will pull the trigger
russ at indy has them for around the same price , I will buy them at indy
BigBlockSam
moparstuart
moparstuart
 :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5:
look what showed up at out hpac mopar cruise  AMC guys
moparstuart
my H beams came friday  :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5: :drool5:
moparstuart
moparstuart
Quote from: moparstuart on July 24, 2010, 07:20:49 PM
Hey..I gots one of them little cars also!!  :D
moparstuart
Quote from: A383Wing on July 24, 2010, 08:38:47 PM
Quote from: moparstuart on July 24, 2010, 07:23:15 PM
are the rods aluminum?
forged steel ,,  I dont think your suppost to drive long distances on aluminum rods , they are for a quarter mile at a time  ?
Quote from: moparstuart on July 24, 2010, 08:40:52 PM
yea..that's why I asked....they sure look shiny on my computer....I wasn't sure
moparstuart
Quote from: A383Wing on July 24, 2010, 08:43:18 PM
Eagle ESP H-Beam Connecting Rods
Connecting Rods, 6.760 in., ESP 4340 H-Beam, Cap Screw, Bushed, Mopar, Big Block RB, Set of 8
3D Design? Rods with a part number ending in "3D" have extra machining in non critical areas to save weight. In some cases they can make engine balancing easier.
EAGLE RODS FEATURE:
Weight matched sets, avaliable individually
Certified 4130 steel, vacuum degassed to remove impurities
EACH Forging is X Rayed, Sonic Tested & Magnafluxed to indure quality
All surfaces are 100% machined
Shotpeened to stress reieve the metal
ARP 7/16" 8740 capscrew bolts (190,000psi) standard. (VW have 5/16")
ARP L-19 rod bolts (265,000psi), are recomended for Small Blocks over 700 hp and Big Blocks over 800hp. and are available at additonal cost
Multi Stage Heat Treated
Packaged in weight matched sets end to end +/- 1 gram
Regular price: $524.95
Sale price: $419.00
EAG-CRS6760C3D
BigBlockSam
QuoteHey..I gots one of them little cars also!
:smilielol:
pettybird
66chargerkid
Unfortunately those fancy rods don't work with press in wrist pinned pistons...
They are for floating pistons.  :'( :flame: :brickwall: :slap:
pettybird
BigBlockSam
hey Mr!
send that motor this way and let some northern boys build it for ya . maybe we can change your black cloud to a gray one  :D
moparstuart
moparstuart
 who sells a new , good  low compression piston and rings for my floating pin rods ?
BigBlockSam
moparstuart
Quote from: BigBlockSam on July 29, 2010, 02:27:05 PM
i would get in touch with the company that sold you the rods and see what pistons they recommend .
i found these on ebay
http://cgi.ebay.com/ebaymotors/Dodge-Plymouth-440-forged-Probe-pistons-flat-top-1-090-/150416080296?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item23057f3da8
yeah i did  mancini quoted me  500.00 buck for pistons and rings  , I was just hoping to not spend that much .   :brickwall: :brickwall: :brickwall:
