Time delay ignition switch light
Started by 471_Magnum, October 16, 2005, 05:51:31 PM
 seen them for sale on ebay  from time to time  , think  they might have been repoped , not 100 % sure though ..... ,
shame you cant get your map lamp to work  ... did you run the yellow from the  map lamp to the door pin switch , then from pin switch to the yellow from the main dash harness with a male bullit connector ?
rikubot
Quote from: tan top on September 23, 2015, 05:50:05 PM
I did not. Is that why I couldn't get it working? I am very bad with electrical. Probably the worst  :D
'69 Charger, 440/727
Quote from: rikubot on September 23, 2015, 09:23:53 PM
below  picture is  how I remember the yellow wires running ,  I would take my kick panels off & glove box liner out &  show you exactly what goes where  , but ! when I replaced ( made ) all the yellow A01 light group wiring , I  altered it from the  factory  lengths & routing &  tapped it up  / wrapped it in its own harness ,  ( as factory is just like spaghetti  behind the dash  :P )   so with out  taking the dash apart and un wrapping all the harnesses  , I cant really help any more sorry .
its pretty straight forward though ,  if you have all the  factory harnesses , with the connections  , like what I named in the first lot of pictures I posted
rikubot
Tan Top, you are the man. Thanks for the diagram! I guess mine was pulled out at some point. I didn't have the relay or any of the right stuff other than the two pin door pins and their connectors. I may try to Frankenstein one together but I noticed the buzzer relays are pretty pricey. Am I looking in the wrong place? On eBay they were going for $50-$60. The wiring layout looks pretty simple too and I located the connector coming off the main dash harness. I think other than the door pin connectors, the only other connector I need is the warning buzzer, so that shouldn't be too hard to find at a salvage yard or the internet.
- Mike
