Spool and the street
Started by Blown70, November 03, 2005, 04:05:06 PM
Blown70
Anyone have issues running a spool on the street?
I have been told fine as long as it does not rain?
71charger_fan
When you go around corners and the outside tire needs to spin faster than the inside won't things get a little hinky? I would imagine that inside tire is either going to lose traction as the tire tries to keep up with the outer one or it will bunny hop. There's a differential back there for a very good reason. I wouldn't dream of it unless your sole purpose is street racing but even then an air locker would probably be a better bet. Expensive though.
golden73
Try getting in/out of a tight parking space or parallel parking with a spool.  :icon_smile_big:
A friend of mine tried it and it was awful in ways you can't imagine.  Turning a corner with a spool at a dragstrip is generally at idle or very slow speed.  Try it at normal speeds and when you feel the rear of the car hopping around to try and make the corner and hear the tires chirping and the suspension banging, you'll quickly change your mind.
'CUDA360
Yup
I have bought 2 cars with narrowed dana 60s already installed and I just take rearends out and stash them
I also have a 8 3/4 too but I sold the spool out of in on E-gay
A little too risky on the street but I didn't like the way the cars handle on the track either.
Maybe if I raced big blocks...
andy74
a local street racer guy was running a spool in his gm, and he told me he would never do it again.broken axles,frigged up rear wheel bearings,and a lot of other bull shit to put up with. get a locker or a good sure grip,youll be happier
And when you break an axle with a spool, you are going to change lanes... instantly!
I would hope thet if someone spends the $$ for the spool they would buy the race axles also
Blown70
Quote from: Chryco Psycho on November 05, 2005, 06:35:42 PM
The rear I have has the Strange Axles in it with the big studs.  I would guess to be a bit stronger no?
Quote from: Blown70 on November 05, 2005, 07:16:38 PM
Strange axles are fine Tom. Go with a locker and it'll be bullitproof.   :icon_smile_big:
Blown70
You saying to ditch the spool too?   GRRR here we go another part I will need.... GRRRR
moparguy01
I ran a spool on the street in HS. If any cops were around you had to go straight.  :icon_smile_big: I wouldnt do it again.
Charger4404spd
Spools are dangerous on the street. Hate to see you mess that pretty paint job up......when it gets painted :icon_smile_big:
