"Painless" wiring
Started by Hemidog, March 16, 2009, 04:43:28 PM
Hemidog
I'm rewiring my whole car, and have almost figured out where all the wires go (Painless mopar wiring)
But there are 4 wires I don't get, which all go to the Instrument panel section:
Black:           Accessory Power (Switched)
Yellow:         Accessory Relay Output
Yellow/Black: Accessory Relay Ground
Black/Yellow: Accessory Relay Activation
What do they mean by "accessory"? just use the on some random thing that needs power? what's "output" and "activation" ?   :shruggy:
Rolling_Thunder
accessory is indeed something that needs power through a relay not provided for already in the harness...   (think like a electric fuel pump for example)
- it needs 12V to go to the pump (accessory relay output)
- The relay itself needs to be grounded to work (accessory relay ground)
- the Relay needs to be triggered by something to activate it and send power to the pump (accessory relay activation)
Accessory power (switched) is a 12V source that is wired to a switch that will send power directly to something then the switch is turned "on"
at least that is the way it seems to be labeled
Hemidog
So these four wires are just coming from a 4 point relay? I think I get it now.
I'm already using two other relays for the headlights, and I don't have an electric fuel pump.
What other things would be useful to run through a relay?
Rolling_Thunder
electric fans
sorry - my mind is mush tonight - I'm sure there are alot of other things.
mauve66
headlight motors on a 1st gen
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
Hemidog
Thanks guys.
Looks like I'll leave those wires for now.
parkerswede
How did you like the painless wiring harness? I am thinking about ordering one for my 3rd gen Charger.
I bet flux capacitors need a relay, that much wattage most certainly can't utilize the standard wiring.
Sorry it's late and I couldn't resist.
Hemidog
You're such a thread hogger Ghoste  :nana:
parkerswede, I really liked the Painless wiring, it's easy to install, all the wires is labeled and has the correct colors.
You get a modern fuse box with small fuses instead of the old glass ones, an accessory relay and horn relay.
The only thing I had to make for myself is the wires for the A/C heater box, and that was easy.
You get at Maxi fuse and installation kit for alternators with higher amps, which I need.
parkerswede
Hemidog
Although I have heard that Ron Francis wiring is one step better!
http://www.ronfrancis.com
FLG
That Ron Francis stuff looks nice, especially the access one. Price seems good too.
Im debating on both now for the future, anyone use the Ron Francis stuff??
terrible one
Quote from: FLG on April 11, 2009, 10:51:14 AM
This might help you:
http://forums.vintage-mustang.com/showtopic.php?tid/1505558/post/last/
Tilar
I've done 3 complete systems using Ron Francis. All 3 were Ford/Mercury systems but their wiring harnesses are all pretty much generic and easy to install.
Dave
mauve66
NEEDS:
body work
total wiring
PW
PDLKS
Tint
trim
alignment
Hemidog
