media blasting??????
Started by 1st_charger, May 03, 2010, 07:46:53 PM
1st_charger
OK I've never had this done to a hole car but am looking into it. Can you tell me what the preferred media is for just removing old paint, filler and light surface rust? and what air pressure to use with that media? I've been hearing alot about soda blasting lately and have a loocal sand blaster that would blast my car but has never used soda. Any info and help is appreciated!
bakerhillpins
Does this help?
http://www.dodgecharger.com/forum/index.php/topic,68127.0.html
http://www.dodgecharger.com/forum/index.php/topic,40908.0.html
Just bump up to the Paint, Body, & Trim section http://www.dodgecharger.com/forum/index.php?board=6.0, Type "Soda blasting" into the search box, hit enter and spend a half hour reading..  :2thumbs:
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
I've heard good things about plastic media blasting. I've looked into soda blasting as it's more readily available around here. The main thing to watch out for is neutralizing it *before* spraying primer. Plastic requires a special setup to capture and reuse the media as it's very expensive while soda is biodegradable (although some places like California are already looking into banning its use outdoors due to some environmental effects). Both are less prone to warping the metal than sand. Neither of these should be applied with standard sandblasting equipment.
I was quoted $700 to plastic bead blast a car and we used to get a "special" rate of around $250 for mobile soda blasting (they come to you) through the club.
xs29j8Bullitt
I used plastic media blasting on my C500 because I believe it is the safest method.
There are pics in my thread, starting in Reply 567, and even You Tube short video clips linked to in Reply 594...
http://www.dodgecharger.com/forum/index.php/topic,33799.560.html
XS
After 8 years of downsizing, whats left...
1968 Charger R/T, Automatic, 426 Hemi
1968 Polara 4Dr Sdn, Automatic, 440 Magnum
1968 Polara 4Dr HT, Automatic, 383
1969 Charger 500, 4 Speed, 440 Magnum
1969 Daytona, Automatic, 440 Magnum
1969 Road Runner, 4 Speed, 426 Hemi
1970 `Cuda, Automatic, 440-6BBL
1970 Challenger T/A, Automatic, 340 6 Pack
2004 Ram, Automatic, 5.7L Hemi
2009 Challenger SRT8, Automatic, 6.1L Hemi
<This Space Reserved for a 2016 Challenger SRT Hellcat, 8Sp Automatic,
