Wing work
Started by 41husk, February 15, 2011, 12:47:31 PM
41husk
The top of my wing is starting to slant.  What size allen wrench do I need to readjust the wing?
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
nascarxx29
Im not exactly sure .But I think its 3/8 allen wrench 7/16 bolt shaft
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
hotrod98
I can't remember what size it is. Dane could probably tell you. It has the limiters built in so it won't slant very far.
I thought we had it pretty tight. If you ever remove the  bolt completely, be sure to put some anti-sieze on it so that it won't corrode and sieze up.
Normal is an illusion. What is normal for the spider is chaos for the fly.
Charles Addams
41husk
I was planning on just loosening enough, to put it back in place then retighten.
moparstuart
  leave it a little slanted and get some down force   :smilielol: :smilielol: :smilielol:
  I leave mine loose enough i can move it around alittle for effect at car shows , but when i put it back in place it usually stays put .
Quote from: moparstuart on February 15, 2011, 04:35:56 PM
Exactly! But not really. The wing actually generates down force when it's level (0 degrees to the air flow, not necessarily horizontal I suppose). It doesn't become neutral until 4 degrees negative (nose facing up in this case).
Brock Samson
  :scratchchin:
Just curious but what are the Lbs. of downforce in the neutural position?.. any handeling advantage at Reg. Freeway speeds?.. Say 70-80  MPH?  or,..  do wingcars need to be in tripple digits to see or feel the stability from the wing come into play?..  Would  increasing the downward angle increase the  grip on turns at a lower speed?..  :shruggy:
The down force increases with speed obviously. ;) I posted some numbers I crunched using a NASA simulator around here somewhere (might have been the old site). If I remember right, below 60 mph there's not much going on (small, thin wing without a huge amount of surface area). You have to remember though that the other parts of the aero package (nose, rear window, A-pillar trim) also contribute to the over all down force and how the car slips through the air and sticks to the road. More down force also means more drag so there's a happy medium in there somewhere for the speed you want to run. In other words, you can't crank the wing to 14 degrees down and hope to run 200 mph.
Brock Samson
Quote from: Troy on February 15, 2011, 06:24:03 PM
   :scratchchin: So,.. I guess that's why WRX's have wings the size of a ping-pong table...  :scratchchin:
Quote from: Brock Samson on February 15, 2011, 06:27:04 PM
And that's what kicked off my "research" - Neal J going off about the big wings on ricers. He claimed the down force would lift the front (drive) wheels off the ground so the wings were pointless. Not so - most are useless since they're generally installed at 0 degrees.
DAY CLONA
All the lift/down force values of every component bolted/mounted/moulded  in to/on to the 69/70 and yes 71 windtunnel test cars/models is recorded in the 300+ page Chrysler  windtunnel test report, makes for a good read, and understanding of how all the components interact/effect with one another
Mike
where can one find a copy of this report?
DAY CLONA
Quote from: A383Wing on February 16, 2011, 12:49:04 AM
Greg K. has one, I also viewed an original at Richard Petty's shop, and IIRC I believe the Aero Warriors sit still has some of the written text on his website, as well as the pics of the 71 windtest models
