Sealing windshield
Started by 1BAD68, March 29, 2012, 01:50:38 PM
1BAD68
A few years ago I replaced my windshield gasket on my 68 and didn't use any sealant.
It leaks, not sure if it's coming from the windshield or not but before I paint, I want to make sure it won't leak.
I found a thread that shows urethane being applied between the windshield gasket and the glass (see pic) but am wondering if anything goes between the gasket and the metal frame?
resq302
There is a product referenced in the factory service manual for replacing the windshield made by 3M which is called Bedding and Glazing Compound.  I used that on my windshield and since then no leaks.  It is like a liquid type butyl that never totally hardens and flexes with the car.
Brian
bill440rt
BTW, urethane was also pumped between the gasket & body. The windshield is mine, & does not leak.
You can also use the 3M Bedding/Glazing compound as mentioned. They used a similar sticky-staying stuff from factory.
1BAD68
Indygenerallee
