Taking it apart
Started by SmashingPunkFan, April 30, 2012, 09:53:02 AM
SmashingPunkFan
 Needing some help before I adjust the car too much!!
Ive heard somewhere before that you cannot move the car once you cut the 1/4s off, so Im trying make sure that Ive set it up right.
I have it setup where the jackstands are under the rear axle, and one under each lower control arm.
Any feedback would be greatly appreciated! :)
Tonight I'm Burning Star IV.
Projects:
1970 Dodge Charger SE (Main Project)
1973 Dodge Charger 400 cid. (Work in progress)
1988 Mustang 2.3 liter 4 cyl.
Looking for Seat tracks for bucket seats.
Quote from: SmashingPunkFan on February 12, 2013, 02:19:43 PM
1/4's are just skin, if it really was part of the support structure it would buckle quite a bit.  Quarters off don't do anything to the car UNLESS everything else rotted away and all that kep the car together was the skin.
If you plan on cutting off more then I suggest you weld a few cross braces in there.  Frame to frame, left to right, high to low.  Now it really won't budge.
SmashingPunkFan
 Ahh ok. Well Ive just heard that alot, and was wondering. I also have the complete trunk pan out right now, Im gonna blast, cover, then maybe remove the 1/4s blast there and then start welding in reverse order.
Btw anybody know how to remove the the little piece of chrome at the back of the rear window? It has some sort of chrome stud in ti :scratchchin:
Projects:
HOTROD
why don`t you brace it all up just in case ! better safe than sorry ???
I have seen some of these guys cut it all off and put it back together !!
What the Hell-Dumass !
SmashingPunkFan
Oh I did. Its jacked under the rear axle and lower control arms. Would those be the correct places to put them?
Projects:
richRTSE
Quote from: SmashingPunkFan on February 17, 2013, 11:29:56 PM
Btw anybody know how to remove the the little piece of chrome at the back of the rear window? It has some sort of chrome stud in it :scratchchin:
there are nuts on the inside of the trunk... those self-cutting, cone-looking things....climb inside there and you'll see them...
FLG
Quote from: SmashingPunkFan on February 19, 2013, 11:18:10 AM
Yes that is correct. You want the car to be supported as if it was on wheels.
