brake booster
Started by hawkeye, September 20, 2012, 06:48:52 PM
hawkeye
taking ideas on what brake booster/master cylinder i can use on my 70 charger with factory disc brakes.  have given up on finding a bendix unit, just need something that will work.  thanks
Mopar Nut
Try Booster Dewey, he has one.
"Dear God, my prayer for 2025 is a fat bank account and a thin body. Please don't mix these up like you did the last ten years."
hawkeye
found a booster #54-73603 at napa.  i am goig to try it along with m/c 10-1475.  if they don't work i'll take them back and try something else.  i have found several posts that say will work and several that say they won't.
thebigmope
I have a factory booster and master cylinder which i removed fronm a 70 charger years ago however i have someone who may be buying the  disc brake setup if he does not want the booster or master cylinder i will contact you, thanks, John.
Quote from: hawkeye on September 22, 2012, 06:03:12 AM
I can almost guarantee that they will not have any of those numbers in stock....  :rotz:
Mopar Nut
Quote from: Just 6T9 CHGR on September 22, 2012, 11:32:50 AM
I guarantee you they will not have one, every place wants you to send a core in. Been there done that. Checked Napa, Checker's, AutoZone, RockAuto, etc, etc ....
PlainfieldCharger
Just bought 2 mater cylinders this week to make sure I get on that works . Summit has the 10-1475 and so did O'reilly Auto parts. Summit was cheaper. They are not the rebuilt OEM cores stamped with the part #. The parts distributor that had them (shipped with their paperwork) is Ozark Automotive Distributors Inc. I think they are in Missiori. They are shipped wet.
Quote from: PlainfieldCharger on October 05, 2012, 07:39:43 AM
Got a pic of it?
hawkeye
got booster 54-73603 and fits fine.  the master cylinder, 10-1475 , feeds out towards the motor.  i need one that feeds out toward the fender well.  need to do more research.  hawkeye
Quote from: hawkeye on October 05, 2012, 08:51:49 PM
Why? Do you have a Hemi car? Only the Hemi's had the fittings facing the fender on the MC
Do you have pics of the units you received?  This is good news if they have these units back in stock!
hawkeye
car came with m/c facing fender, just figured it was correct.  i have seen them both ways.  pictures of booster attached.  have tried several times to post but never could get it to go.  thanks hawkeye
Quote from: hawkeye on October 06, 2012, 01:36:28 PM
Ah ok.  Thats not the "correct" Bendix booster but it will do the same job regardless!  :cheers:
hawkeye
i didn't think it would be the bendix unit but no one had one that was even the 'functional equivalent'.  everyone said i wouldn't even be able to do that. hawkeye
