Daytona length
Started by 41husk, January 07, 2013, 09:10:41 AM
nascarxx29
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
held1823
i used an older version of this one to keep from crushing the dryer vent with the quad cab. dryer vent, bumper, nose cone - 'tis all relative...
http://www.amazon.com/PZ-1900-Platinum-Power-Garage-Parking/dp/B001VJZOBO
Ernie Helderbrand
XX29L9B409053
WINGIN IT
Quote from: held1823 on January 07, 2013, 09:21:11 PM
Now THAT one is more doable for my situation.
Does it work well?
41husk
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
held1823
Quote from: WINGIN IT on January 09, 2013, 09:28:15 AM
Does it work well?
like a charm.
Ernie Helderbrand
XX29L9B409053
Bob T
My version is more low-tech , I agree about the tennis ball being in the way so I siliconed a small thin strip of ply onto the floor in front of the wheel, just creep up to it, easy as  :2thumbs:
Old Dog, Old Tricks.
winged69
This is just thoughts on parking a daytona in a 20' deep garage. Depending on stud size, 2x4 or 2x6 I found my car would not fit. You would have to put a lean to or cut a slot in the back wall to allow it to fit. Also remenber to watch overhead door as it  is generally inside the wall perrimeter and you could put the door down on your nose cone or wing and trunklid.  Also do not forget if your car has a four speed there is no neutal start switch, you are not leaving much space if you forget to put clutch in or someone other than you tries to move it.
Also in regards to backing in, watch the wing. i can remember backing a wingcar into a garage and it seemed to me that the wing was canted back enough to touch the wall before the rear bumper. Could of been a case of sunken floor in garage or garage itself had shited under its own weight.
I have another caution.I am looking at building a garage  tall enough to put one car on a hoist and drive another one in underneath. it is a wonderful idea, but unless you put a vaulted ceiling in, a sliding overhead door just might take the top of the wing off when you open it.I  am thinking of a left or right sliding door instead.
All my ideas hing on a city approval and they are not very helpful, put in restrictions and of course raise taxes since there is more building to tax.
41husk
If I buy this building I hope to build a shop in the near future, so this would be a short term parking problem, but I have 21 ' in one garage so I think I am fine.  Just need to negotiate a price.
winged69
Just remember that 20' is outside measurement of garage. Do not forget to reduce this by 2"x4" construction or 2"x6" studs for framing.  This can reduce the 20' down 1/2 '.. Also garage doors are set in so you might lose even more.  I found trying to put my Daytona in a 20' deep garage appeared to need a lean to or slot in door to allow nose to poke out. Also it may be an optical illusion but it seemed to me the wing was canted toward the back and might be first piece to hit the wall.
Lastly you can not walk around the car and if you have a garage door opener you do not want to test the reversing method by having it try to come down on the nose.
