Painting Magnum 500s
Started by 5hunert, April 28, 2013, 11:18:54 AM
5hunert
I need to freshen up a set of 1969 magnum 500's.  I'll probably use poof cans for the black - What level of flatness is correct?  Semi-flat?
Also, I seem to remember a few years back seeing precut masking kits for Magnum 500s; does anyone know where to get them?
ODZKing
I use "Trim Paint".  It is sort of a semi-gloss and matches perfectly.
It also has primer in it so it sticks to almost anything.
As far as the masking kit ... ha!  That is my wife   :rofl:
Mopar Nut
Quote from: 5hunert on April 28, 2013, 11:18:54 AM
YearOne has them.
Quote from: ODZKing on April 28, 2013, 11:24:08 AM
Mine too, they must have took the same training.  :smilielol: :smilielol:
5hunert
Thanks!
Are you referring to Rust-Oleum Trim and Bumper Paint?
http://www.summitracing.com/parts/rll-251574/media/images
resq302
Those masking kits they make for the Magnum 500s are absolute trash!  They did not fit anywhere close to the curves that they were supposed to.  I ended up pulling them off and tossing them into the garbage and ended up using the blue painters tape and then went around it with an exacto knife!
Brian
Fred
Quote from: resq302 on April 29, 2013, 09:37:56 PM
Just goes to show what you can waist your money on.  Probably made in China.........nothing made over there fits, not even clothes.
ODZKing
Exactly what Martha does.  She has the patience for it.  I even bought her the super thin masking tape to make her efforts a bit easier on the edges!!    :icon_smile_big:
resq302
Thats what I did with the satin chrome part where it meets the inside edge of the rim.  I first put down 1/4" vinyl automotive painters tape and then went over it with the blue Scotch brand painters tape.  The vinyl tape made it so much easier to go around corners with!
Brian
5hunert
Thanks for the info about the quality of Year One's masking kit.  I'll skip that one!
resq302
It'll actually be cheaper if you just use the painters tape.   :2thumbs:  (and probably get a better job out of it!)
Brian
