air compressor
Started by cdr, August 29, 2013, 10:59:35 PM
cdr
well today was  :flame:  my 1000.00 air compressor went eeerrrrrrrrrrrrr & the motor burst into flames,glad i was home when it did it,i have been known to forget to turn it off when i leave the house,  this really sucks!!!!!  SO MUCH for workin on the charger   :RantExplode:
ws23rt
OOps good thing you were home.  I to try to remember to turn mine off when I leave home.
Was gone for work one time for three days and came home to find the toilet running (flapper stuck open).  Big water bill that month :shruggy:
sanders7981
Ingersoll-Rand model?   :popcrn:
Cooter
Awe no cdr....dang, you know I'd lend you mine ifin I's closer guy. I think lowes.home depot grainger.etc have just the electric motors fairly priced.  Sorry it happened man.
charge69
That's gotta suck, Charlie!  Replacing the motor is not really that expensive but, is the compressor pump OK or did it freeze up causing the motor to fail?
Silver R/T
What happened to it? Was it just too old or there's not enough oil in it?
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
cdr
Quote from: sanders7981 on August 29, 2013, 11:59:22 PM
yes to the ingersoll,i got on the web & apparently this is a common problem.. its only about 5years old,very little use,the pump is still ok its just the motor.
COOTER THANX  you are very kind.
sanders7981
Quote from: cdr on August 30, 2013, 12:22:45 PM
Sorry for your troubles, that sucks.  That is the EXACT reason I didn't get an IR model.  I did a bit of research on them and found that this happens quite a bit. I ended up getting a Quincy model on sale for a pretty good price.  Good thing you were home though, could have been much worse.
Mopar Nut
That was close, someone was watching over you or the Charger. Glad to hear there was no serious damage.
