winter starts
Started by tucknroll, November 02, 2013, 03:44:34 PM
tucknroll
anyone have any good ideas to help with winter cranking. the car cranks fine but I would like to make it a little easier on it for really cold mornings coming up. I read that some people use an electric blanket under the hood. any thoughts?
block heater would be my first choice....problem with the blanket is that it will not get the engine very warm, heat rises, the block will still be cold...and those electric blankets are not made for outside use...indoors only, no moisture
Dmichels
I think they use to have a dipstick heater to keep the oil warm
68 440 4 speed 4.10
NHCharger
Heated garage usually does the trick ;)
I think a block heater is your cheapest and most reliable way to go.
72 Charger- Current money pit
68 Charger-R/T Clone- For Sale this Spring.
69 Charger Daytona clone
88 Ramcharger 4x4-
1975 Chrysler Conqueror 135 (boat)- (another moneypit)
2014 RAM 2500HD Diesel
hawkeye
They also make a heater that is a magnet .  You just put it on the oil pan.  Synthetic oil also helps.  http://www.amazon.com/Kats-1160-300-Watt-Handi-Heat-Magnetic/dp/B000I8YOR4/ref=pd_sim_auto_1
flyinlow
Drop light next to the intake manifold helps. Use an Al Gore approved 100 watt bulb.  Won't crank faster but a warm intake helps vaporize the fuel and will start easier.
Dmichels
Quote from: flyinlow on November 08, 2013, 02:29:11 PM
You have a 100 watt light bulb where do I get one of those??
68 440 4 speed 4.10
