FEL-PRO 8519SP spacer
Started by Nacho-RT74, May 12, 2014, 03:07:02 PM
I have read these being head savers... but... I guess can be used the same over the block deck... right ?
is it safe?
can be used the same with metallic and composite headgaskets ?
cudaken
http://www.summitracing.com/parts/fel-8519sp
Sure you seen this link. Looks like it is spacer that is used with a head gasket.
Why are you thinking about them Mo Jo? (yep I am old) Is it because you had to have the heads cut? There spacers that fit under the rocker arm shaft if that is the cases.
Ken
I am back
Mo Jo is another guy LOL
no, because I got a bad block decking job, mostly sure will require to cut down again, and pistons will leave a little bit the block
