Newbie in the UK
Started by slumbers, November 29, 2014, 03:15:47 AM
slumbers
Hi Guys !
                   Greetings from across the pond ! I have just purchased a 68 Charger R/T   :2thumbs:  from Utah for restoration which is currently in transit  back to good "Ole Blighty"  . Quick question , this car needs rear lower quarter panels as its gone around the wheel arches and lower rear end . Is it easier to replace the whole rear quarter panel or just the lower half. I can see the lower panel repair section kind of ends at the top of the rear "Fender" are these easy to fit and blend in bearing in mind this is a long panel and the car is going to be painted Black ?  :o  Any advice would be Great
JPM
Welcome !  :cheers:
To eliminate a maximum of rust in the inner side of the rear fenders, choose full face panels...  :popcrn:
The work I realised on mine : http://www.dodgecharger.com/forum/index.php/topic,114469.0.html
In rust, I trust...
polywideblock
don't forget outer wheel house and trunk extensions  :yesnod:
welcome    :cheers:
  and 71 GA4  383 magnum  SE
Mopar Nut
JPM
Do it right, do it once !  :2thumbs:
(69 panels figured below)
In rust, I trust...
It makes the work after appear better since there is no seam to be blended in halfway down the panel.  Welcome to the group.
Daytona R/T SE
Quote from: polywideblock on November 29, 2014, 03:51:48 AM
And rear valance and corners.
Rear cross member.
Trunk floor.
Frame rails.
Dutchman panel
Floor pans.
Rocker panels (Inner and outer)
Etc.
Etc.
Etc.
Welcome aboard! :2thumbs:
moparnation74
Welcome aboard!
Where in ole Blighty are you?  I lived in Manchester for a little while which is ironic because when I moved to the US, I ended up in Ann Arbor which is very close to Manchester, Michigan.   :icon_smile_big:
slumbers
Thanks Everyone ! I am in Sussex in England , From the amount of panels I may need sounds like an English Ford Capri I have just finished
polywideblock
looks  great   :2thumbs:   3 litre ? don't think anything rusts like early capri's and  escorts  :scratchchin:
slumbers
Not 3 Litre ...............Rover 3.9 , Offenhauser 360 Dual plane Manifold , Holley 390 , Fast road cam , Cloyes steel Timing gears , straight through sidepipes..........Sounds like Thunder Goes like Lightning  :2thumbs:.  Hopefully only the Dodge will Be better ? I've wanted one since I saw Bullitt in the 70's ;)
I had a Capri or two, but not that peppy.  Still, very nice cars.  Yes the Dodge will give you a bit more smile going down the road, no doubt about it.   :icon_smile_big:
JPM
In rust, I trust...
Mopar Nut
Nice job on the Capri!   :2thumbs:
