Using oil
Started by Bob, July 17, 2016, 05:34:51 AM
Bob
Just drove 300 miles and used about 3/4 of a quart of oil. No smoke during start up or driving. I don't want to do a tear down so is there a good additive to slow the loss?
Also, there are no leaks.
1974, 400 4bbl, auto.
Bob
Highbanked Hauler
 What weight oil are you using ?
92 Cummins Turbo Diesel
04 PT Cruiser
PlainfieldCharger
Small intake leak leak at the valley pan gasket sucking in oil... just a place to look that is out of the ordinary. :Twocents:
Bob
Challenger340
Is this a new Engine build ?  Old Engine ?  How many miles ?
Only wimps wear Bowties !
Bob
Quote from: Challenger340 on July 17, 2016, 11:35:08 AM
Original engine 82k. Had new gaskets and valve guide seals back in 02-03 but nothing done to the bottom end.
Highbanked Hauler
Quote from: Bob on July 17, 2016, 05:34:51 AM
Bob
     Get some straight 50 weight from Brad Penn for the summer but change it out for cold weather..
04 PT Cruiser
Almost a quart in 300 miles and no leaks or smoke?   :scratchchin:  it is going somewhere. I would say if there is nothing wet underneath, then pull the spark plugs and see what it looks like, if you find oil fouling evidence then the next simplist thing to do is pull yhe intake and look down the runners to see if it was a leaking valley pan. If the ports are clean, its a wore out motor.
Bob
Quote from: c00nhunterjoe on July 18, 2016, 10:42:45 AM
Since it would be awhile before I tear into it I believe it's just a tired motor. Probably needs rings since the last time I pulled the plugs they were fouled black.
Fuel fouled and oil fouled will look completely different on a spark plug. Could you post a closeup of the plugs? Were all 8 identical looking?
Bob
Quote from: c00nhunterjoe on July 18, 2016, 03:20:46 PM
Give me some time and I'll post them.
Thanks for you help.
Bob
Bob
Not the best pictures but it's the best I could do. I replaced them with original Mopar plugs. Right side is the front of the engine and go left to the rear.
Challenger340
Did you just recently switch the Engine over to Synthetic Oil ?
Bob
Quote from: Challenger340 on July 19, 2016, 07:13:59 PM
Yes, I thought it would slow down wear.
My personal opinion is not to run full synthetic on a flat tappet cam. I would swap back to a good syn blend oil, bradd penn is my preference.
    What valve covers are you using? Are they baffled? Pcv?
   It looks like the further to the rear of the engine, the more fouled they become. Are there deposits on all of the plugs like the bottom left and top left ones?
Challenger340
Quote from: Bob on July 20, 2016, 02:38:40 AM
Bingo !
There is your problem.  Synthetic Oil when introduced to a higher mile older Engine with already glazed Cylinder walls is a recipe for Oil consumption.
The stuff is just plain too slippery....
and what was still sealing OK on Dino Oil, will quickly lose that remaining sealing ability on the slipperier Synthetic.
Now the bad news, IMO, I highly doubt just switching back to Dino Oil will cure the problem as the stuff seams to coat the metal ?
In my experience, damage done.
You can certainly try switching back to Dino Oil, just say'in..... you may find it doesn't work after a few hundred miles on the Synthetic.
Bob
Quote from: c00nhunterjoe on July 20, 2016, 06:33:24 AM
Everything is stock to include the factory valve covers. You are correct about the plugs. The further back they were a little more fouled.
Bob
Quote from: Challenger340 on July 20, 2016, 09:30:36 AM
Bingo !
I probably ran 4-500 miles on that oil. I will switch back and see what happens.
Thank you.
Bob
Will a high detergent oil help clean it up?
68CoronetRT
If this is a flat tappet motor I'd be worried at this point of burning up the cam due to lack of zinc.
High detergent oil is for air compressors.
Challenger340
Quote from: Bob on July 23, 2016, 08:00:40 AM
In my experience, only a re-hone of the Cylinders to get the rings biting again will clean it up ? which involves a teardown.
That said,
what have you got to lose trying anything at this point ?
* High Detergent ?
* Low Detergent ?
* Engine "restore" in a can ?
* Powdered Bon ami ? (Diesel fix to get old rings sealing again)
* whatever ?
Run the dog crap out of it, get things flexing. If nothing else, you'll have fun.
Bob
And here I thought I was doing a good thing for my engine.
Crap!!!!!
Thanks for your help.
Bob
flyinlow
A quart in 400 miles is not the end of the world.  The plugs (depending on how many miles are on them) don't look that bad. The left lower one is showing oil consumption. Worn rings will show oil smoke under hard acceleration. BB  Mopars I have worn out show oil fouling on the rear cylinders first.  If you drive 2000 miles a year and the plugs go that distance , keep driving. Check your oil every fill up.
Bob
Narrowed down to Bon Ami or Seafoam with an oil change.
Thoughts?
