Stealth head work
Started by C500, October 30, 2016, 10:51:56 PM
C500
Picked up my heads from my local cylinder head experts, flow data and pics below.
They performed a street port job, strip, de-burr and polish valve stems, hone guides, redo valve seat angles, machine valve seats, porting and chamber improvements, mill heads to 80cc, initial flow test on an SF-600 'Superflow' flow bench, and final flow test to compare.
Cam lift is 0.496 HDP271. SF-600 tested at 28" H²0 Heads went from 250.6cfm to 287.8cfm intake, exhaust 192.6 to 207cfm. Engine Compression ratio will be 10.2. Pretty happy with the results  :yesnod: Comp Cams retainers and keepers, and 911 springs installed.
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
C500
a couple more....
C500
and some figures.... ignore the dirty four letter 'f' word on results sheet
Excellent numbers @ .500 lift. Should make for a fun ride.
C500
BSB67
very nice!
Good heads, good compression, you're 90% there
11.68 @ 120.2 mph
Challenger340
Only wimps wear Bowties !
C500
Nice job....great results.  :icon_smile_cool:
That's going to be a huge improvement over the factory heads and less weight to boot !  :2thumbs:
500Jon
Nice heads there!
Hope your fuel is better than ours in the UK?
We struggle with anything over 10 to 1 and Bigblock.
Smallblocks seem to fair better at higher comps.
The exhaust ports look taller than the 906 heads?
Are you going to use headers?
5J
IF A JOB's WORTH DOING, ITS WORTH DOING WELL, RIP DAD.
4-SPEED, 1969 Charger-500 is the most Coolio car in the World!
C500
Quote from: 500Jon on November 05, 2016, 05:10:03 AM
Nice heads there!
5J
Our fuel is not great, I will need to run it on premium at that CR, 10.2 will be fine. I had the heads port matched to my cast iron HP manifolds.
