Starter heat wrap
Started by comet_666, April 15, 2021, 09:10:27 PM
comet_666
Any recomendations on a starter heat wrap/shield?
it's a mini starter, don't recall the brand, after car has been running it struggles to turn over.
Mopar Nut
"Dear God, my prayer for 2025 is a fat bank account and a thin body. Please don't mix these up like you did the last ten years."
comet_666
Mopar Nut
I would use your header wrap brand if you can get it in shorter lengths. Odd I haven't heard of mini starters get that hot. Do know how old the starter is?
Check for adequate power and grounds. Ive always run extremely tight clearances and even had tube touch the starter without issue. If your headers are wrapped and it still does it, i doubt its a need for more wrap.
comet_666
Quote from: Mopar Nut on April 16, 2021, 03:41:38 PM
Don't laugh, but I remember replacing the starter back in the early 90's with a mini starter, it's probably the same one. Works perfectly when cold.
It did look great when I had the motor out a few years ago so I stuck it back in.
Mopar Nut
That's a good life for a starter.
comet_666
I agree, maybe time to replace?
