68 hood latch too tight
Started by grdprx, August 14, 2025, 02:55:43 PM
grdprx
I feel like my hood has too much pressure on it when it's latched on my 68.  The latch is as high as possible, what other adjustments can I make?  The adjustable rubber bumps have even body lines, maybe the fender needs adjusting?
70 sublime
Did you try it without the pop up spring ?
Quote from: grdprx on August 14, 2025, 02:55:43 PMThe adjustable rubber bumps have even body lines,
Not sure what you mean by that, have you tried temporarily removing them?
grdprx
Sorry John, that didn't make sense.  I had previously had the adjustable bumps lower, but the hood didn't line up with the fenders.  I recently got it painted and was trying to fix the gap and alignment.  Seems to me that the pressure is excessive when I release the latch.  And I actually am missing the pop-up spring.
Waller out the holes to move the latch up.
grdprx
Quote from: b5blue on August 15, 2025, 06:36:43 PMWaller out the holes to move the latch up.
Sounds like my best solution, thanks!
