Heater blower
Started by tucknroll, November 01, 2025, 10:38:11 AM
Rocky05
Quote from: John_Kunkel on December 20, 2025, 01:57:43 PM
Quote from: tucknroll on November 14, 2025, 02:38:15 PMHow do I bypass the resistor? Running on high is fine with me
Not sure if that is a good idea, bypassing the resistor block permanently might overheat the motor.
Looking at the wiring diagram, it appears that there is some resistance even in the high mode...IOW, it never runs at full 12V. :shruggy:
Electrician here:  if it can't run at 12.6 volts the battery puts out, it can't run at the 15+ volts the alternator puts out.
These DC motors are very robust.
