Broken Vacuum Port
Started by tomonty, June 19, 2007, 06:20:16 PM
tomonty
So I was taking the center carb off of my six-pack to put in a new power valve and to put in some different size jets and while I was taking off the right front bolt, I didn't notice that the edge of the socket caught on the vacuum port for the secondary carbs and broke it off :brickwall:
So anyways, I was wondering if I drill it out and put in what is left of the vacuum port, can solder it and have it be ok? Or am I sh&t creek and have to buy a new carb?? Any help would be awesome. Thanks guys.
Mike
It is inaccurate to say that I hate everything. I am strongly in favor of common sense, common honesty, and common decency. This makes me forever ineligible for public office. - H.L. Mencken
Back N Black
It should be ok ,maybe even a little 5 minute epoxy will do the trick?
Charger-Bodie
Quote from: Back N Black on June 20, 2007, 11:18:22 AM
:iagree: drill it out carfully and the epoxy it.
SUPERBEE123
be very care if you drill it out those shaving could come back and give you big troubles. can you run a small screw into the hole and pull the port out a bit and them epoxy ? good luck
tomonty
Thanks for the advice guys. I will the expoxy a try. I drilled out what I could of the port and then blew it out with air and then carb cleaner, so hopefully I won't have any problems. Thanks again.
Mike
