DodgeCharger.com Forum
July 03, 2009, 05:12:08 PM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Search Calendar Login Register Chat
Pages: [1] 2  All   Go Down
  Print
Author Topic: OOPS...  (Read 746 times)
alfanta
Junior Member
Offline Offline
WWW
« on: June 28, 2007, 09:15:05 PM »
so i just got my transmission rebuilt, and after doin all the stuff to make sure its ready to go, driving it short ammounts of time to make sure its all right and stuff, ya konw taking it easy for a littl ewhile, i drove it 2 hrs from findlay ohio to cincinnati where I am going to school, well about 15 min from my place i blew something out the oil pan. There is a hole about the size of a nickel in the side of it. I donno what it was, but its definitly not good. Im thinking im going to have to rebuild the engine.
It originally had a 318, but I have a hookup on getting a 440 with transmission for only $300. Do you guys think it would be worth changing it? Its already not a numbers matching car the trasmission was change when the case cracked. Since I have to rebuild the engine anyways Im thinking just rebuild the 440. I dont know what all I will need to replace, can anyone tell me so I can look at the finances of it and see if its worth it? Im guessing mounts, transmission, exhaust, just off the top of my head. Does the wiring harness need changed?
Let me konw what you guys think.
-RJ
Logged
Charger1973
Resident 3rd Gen Charger Freak
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #1 on: June 28, 2007, 09:17:43 PM »
If its a 73 or newer you need a different K frame or else you need to buy the conversion mounts.  72 and older just change motor mounts...
Logged
BEWARE: Kreative Customs of London,KY screwed me out of $40
alfanta
Junior Member
Offline Offline
WWW
« Reply #2 on: June 28, 2007, 09:25:16 PM »
it is a 73, thanks.
Logged
alfanta
Junior Member
Offline Offline
WWW
« Reply #3 on: June 28, 2007, 09:46:24 PM »
what about the conversion kit available from year one?
http://yearone.com/pco/1_0906/0179z.asp
is that good, have people used that? I havent done an engine swap before, but i have rebuilt an engine before so I will be able to do it. I just want to get all my ducks in a row first.
Logged
Charger1973
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #4 on: June 28, 2007, 10:28:27 PM »
http://www.engine-swaps.com/
Those sound good from the ad.  Heres a link to a site I always hear about.  Ive never used the mounts though, so I cant say.  Im changing my K frame.  I have a 318 car with a 400 motor.
Logged
68chrgrwife
Old Timer
Offline Offline
(sounds good)
« Reply #5 on: June 28, 2007, 10:45:11 PM »
You would need to change out the engine wiring harness too.
Logged
MOPAR OR NO CAR BABY!
LOVING MY HUBBY: CHARGERMAN68
1973 DODGE CHALLENGER: SOLD Sad
1968 DODGE CHARGER RT CLONE (OK, SO IT'S HUBBY'S BUT IT'S MINE TOO, RIGHT?)
2008 DODGE CHARGER
2005 DODGE MAGNUM R/T (YES IT'S GOTTA HEMI)!
alfanta
Junior Member
Offline Offline
WWW
« Reply #6 on: June 28, 2007, 10:51:38 PM »
ok, thanks. What about upgrading brakes/suspension like ive heard suggest and Definitly am thinking is a good idea  icon_smile_big I dont wanna rear end someone or tear something apart. Right now I would like to know the MINIMUM amount that i have to upgrade and change on the car in order to get it to be safe to operate, later down the line i will work on making it handle great, etc. I am planning on eventually upgrading to disks in the rear. Im also looking at some of the weight saving possibilities on the front end.  MAYBE something along the lines of this in the far future. Knowing my luck not any sooner than 2 years
http://www.magnumforceracing.com/magnumforce_tubular_kmember.htm
Logged
Charger1973
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #7 on: June 28, 2007, 10:54:03 PM »
73s came standard with front disc brakes so you are fine there.  I would just rebuild them...  but its up to you what you want to do.  You could always convert to disc in the rear too but I dont know the details of that swap, its something I havent got to yet...
Logged
68chrgrwife
Old Timer
Offline Offline
(sounds good)
« Reply #8 on: June 28, 2007, 10:56:54 PM »
We upgraded ours and I believe that we also had to change out the rearend....
Logged
2008 DODGE CHARGER
alfanta
Junior Member
Offline Offline
WWW
« Reply #9 on: June 28, 2007, 11:28:18 PM »
Ill look at the rear end that i have, I THINK, i have the 8 3/4 rear dif. I dont know if that was available in 73 or not, but this car was so bastardized by its previous owner that he may have changed it. anyways, I had a leak and had the change out the gasket, and i think the gasket i got was for that. all i know is its one heavy mofo. lol How can I identify the rear end? can i count the bolts? I think when i fixed the leak it had either 9 or 11 bolts. I cant remember though.
The rear disc conversion will wait if possible, I just want to make sure it is safe. The front suspension system that i posted the link to I will not be buying for a while, like I said its more likely to be 2 or more years down the road. So do i need to upgrade the brakes on the rear? or are the drums ok? I seem to remember the drums being bigger than they were supposed to be as well. I think i my have 10.5" drums? what sizes were put on them?
ok so list so far (aside from typical engine rebuild parts):
Mounts/k-member
Wiring harness-Thank god, mine was so terrible anyways.
Transmission (im planning on using my internals from my rebuilt one with only 200 miles on it in the case of the 727 BB)
I guess im gonna have to start selling parts off my 318...I have an edelbrock intake and carb...only a 650. rotz far too small for the 440
Is $300 a fair deal for the motor and tranny? The guy SAYS it was running when he parted everythign else out, but we've all heard that story.
Logged
68chrgrwife
Old Timer
Offline Offline
(sounds good)
« Reply #10 on: June 28, 2007, 11:34:24 PM »
Mounts/k-member
Hubby says that you can tell what rear end size you have by the size of your brakes.. (pretty sure) 8 1/4 rear end would have 9 in. brakes (which is what you should have for a 318 engine, but it could have been upgraded to a 8 3/4 if there was a different driveshaft placed in it)...8 3/4 would have 10 or 11 inch brakes.   You need a 8 3/4 rear for a 440/727 trans.
Logged
2008 DODGE CHARGER
alfanta
Junior Member
Offline Offline
WWW
« Reply #11 on: June 28, 2007, 11:43:32 PM »
ok, thanks for the info. Ill check that out tomorrow when its not 2am  icon_smile_big
If anyone still has some input, I would definitly appreciate it. Im going to bed now, taking a trip to the junk yard tomorrow and then to check my charger after that. I Appreciate the help.
-RJ
Logged
alfanta
Junior Member
Offline Offline
WWW
« Reply #12 on: June 28, 2007, 11:58:23 PM »
If my car was a 318 with a 727 what rear end SHOULD it have?
Logged
Charger1973
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #13 on: June 29, 2007, 12:10:07 AM »
8 3/4 rear ends dont have a cover on the back, its welded and the center section pulls out from the front side.  Heres an ID chart that should help.  For a 73 318 car I would guess its an 8 1/4
http://www.dodgecharger.com/forum/index.php?action=dlattach;topic=25934.0;id=38994;image
Logged
Charger1973
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #14 on: June 29, 2007, 12:11:38 AM »
And $300 for a running 440 and trans is a damn good deal...  if its in the shape he says its in.
Logged
alfanta
Junior Member
Offline Offline
WWW
« Reply #15 on: June 29, 2007, 12:26:10 AM »
ok now im 90% sure its an 8 3/4. I had to pull the dif out to the front to get the gasket on. Ill check anyways though. Thanks.
according to that info the 440 should have the Dana 60 rear end. should i look at upgrading to that rear end in the future or will the smaller one suffice? what kind of performance differences are there? I MAY be able to pick up the rear end from the guy that im getting the engine from as well if he still has it.
As far as it being in the condition he says its in, well we have all heard that story "It ran when I pulled it out". I saw a pic, It looked like it needed rebuilt, Im planning on rebuilding it, and taking the time to do it right. I know at this point I will not be driving my charger the rest of this year. sadly.
Logged
alfanta
Junior Member
Offline Offline
WWW
« Reply #16 on: June 29, 2007, 12:27:19 AM »
Maybe I have that rear end b/c I have a 727?
Logged
Charger1973
Old Timer
Offline Offline
1973 Dodge Charger
« Reply #17 on: June 29, 2007, 12:44:16 AM »
Every 73 or 74 Charger I have had came with the 8 1/4 and that includes 5 318 cars and 2 400 cars.  I dont know the details on what came with what specifically or even if the info on that chart is correct.  I just use it for the pictures.  If you pulled the center section out the front then it is an 8 3/4...  unless someones really done some customizing and its a rear end from another vehicle like a Ford 9 inch or something like that.
Logged
alfanta
Junior Member
Offline Offline
WWW
« Reply #18 on: June 29, 2007, 06:29:55 AM »
ok, well like i said when i bought the gasket I thought i rememberd getting the 8 3/4 bolt pattern one. Like I said, this car has been bastardized so much, wouldnt the ford 9" be a good thing? aside from the fact its a ford part icon_smile_big icon_smile_big icon_smile_big icon_smile_big
Logged
Charger74
Senior Member
Offline Offline
73 Dodge Charger SE
« Reply #19 on: June 29, 2007, 08:48:06 AM »
[ I am planning on eventually upgrading to disks in the rear. Im also looking at some of the weight saving possibilities on the front end.  MAYBE something along the lines of this in the far future. Knowing my luck not any sooner than 2 years
Quote
Don't bother, they won't work on 73 and up.  This stuff is only for 72 and older.  Our front ends/k members are completely different.  You may be ok running to 440 with the disk brakes on it currently, ran mine for almost 10 years setup that way.    I would suggest upgrading the torsion bars though, the stock ones may not hold up for very long.
Logged
Quote
Pages: [1] 2  All   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.068 seconds with 16 queries.
