2nd gen dash removal
Started by charge it, July 21, 2007, 09:04:07 PM
charge it
any pics or diagrams maybe a walk through on where the screws/bolts are that hold the dash in? need to remove can't find bolts. thanks
charge it
69 charger rally dash if this info is needed. thanks
beenaround
You have to remove the windshield if you are looking to remove the entire steel frame of the dash.If you just want to remove the cluster you will need to lower the steering column.
AKcharger
To pull the entire dash the windshield MUST come out, no way around it. Once it's out I recall 4 bolts near the window frame and two bolts on  the sides one near the glove box and the other by emergency brake release. Of course all wires and duct work needs to come out too, here's the best picture I could find
charge it
ok guess the windshields coming out. that would explain why I couldn't find the bolts. thanks for the info.
