Cam woes
Started by Dodge69_440, August 21, 2007, 08:51:21 PM
Dodge69_440
Ok I installed a voodoo cam in my 360 and got it all put back together.  I got it started and noticed a mechanical clicking noise coming from the engine.  The cam is a hydraulic flat tappet.  My question is, is there normally a clicking noise that goes away after break-in?  I know this is unlikely, just asksing.  More likely I didn't adjust my roller rockers properly.  Thanks for the help I just don't want to shred my new cam.  I go back to school in a few days so time is running short!
Charger-Bodie
they will click for a short time on first start up but thats about it. prob. needs rockers adjusted  did you break the cam in?
Hopefully you broke the cam in with good lube and used the proper procedure. Assuming that was done correctly it could be a loose rocker arm that needs to be tightened up. With hydraulic lifters you need to pre-load the valvetrain .020 inches. This is done while the lifter is riding on the base circle of the cam.
