DodgeCharger.com Forum
December 04, 2008, 05:18:56 PM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Search Calendar Login Register
Pages: [1]   Go Down
  Print
Author Topic: Resonance sound  (Read 686 times)
Belgium R/T -68
Full Member
Offline Offline
« on: April 12, 2008, 03:51:23 AM »
I will try to explain a problem I have with "resonance" sound as I call it. My GTX -69 vert gives at certain RPM/highwayspeeds a sound wich makes it really uncomfortable to drive the car.
It's not vibrations, not the sound of the "engine". It's like the rearend at certain speeds gives this phenomen. It's really terrible for your ears. My Chrysler 300 vert -69 have the same
engine,transmission and rearaxle + gears and is a dream to ride. You don't even hear the engine in a matter of speaking. The only difference is that the 300 have a single exhaust system.
Any possible explanations?  scratchchin
Logged
NOT Just 6T9 CHGR
Global Moderator
Old Timer
Offline Offline
When ya can't just have one...
WWW
« Reply #1 on: April 12, 2008, 04:56:54 AM »
By chance do you have Flowmaster mufflers on there?  Most chambered style mufflers will give you cruise RPM resonance
Logged
74Rallye
New Member
Offline Offline
« Reply #2 on: April 12, 2008, 08:13:35 AM »
I have the same problem with my SpinTech mufflers around 1900 to 2300 RPM. From what I've read, if the tail pipe is 1/2" smaller in diameter it can help a little. I'm considering drilling through the muffler and using a long bolt to "dampen" the vibration of the muffler at resonance. Another thing I've been thinkling about is adding a pluged pipe to one end of the muffler to tune out the resonance.
This link will help to understand the forces of resonance:  http://en.wikipedia.org/wiki/Helmholtz_resonator
Logged
andy74
Old Timer
Offline Offline
sure do miss old blue 72
« Reply #3 on: April 12, 2008, 03:31:15 PM »
i have thrush turbo mufflers on mine,with dual 2 1/2 inch pipes,and at some rpms i get a resonance through the car,just a little off idle,i think every type and brand has some
Logged
Belgium R/T -68
Full Member
Offline Offline
« Reply #4 on: April 17, 2008, 12:26:22 PM »
Mine is definetly coming from the exhaust system. 3" H-pipe system with one dynaflow muffler, no headers. Is this to big and causing the resonance?  shruggy
Logged
Tilar
Full Member
Offline Offline
« Reply #5 on: April 17, 2008, 01:37:18 PM »
Probably. The cheapest out, and to test your theory would be to put a resonator in line. Basically it's just a second muffler.
Logged
Belgium R/T -68
Full Member
Offline Offline
« Reply #6 on: April 17, 2008, 02:46:54 PM »
Can you explain that a little bit moore.  scratchchin
Logged
Tilar
Full Member
Offline Offline
« Reply #7 on: April 17, 2008, 04:23:57 PM »
Back in the mid to late 70's, Just after the muscle car era, They started adding what they called a resonator to exhaust systems. These were put on the higher horsepower systems to quiet them down. They were generally added behind the rear differential with the downspout of the tailpipe coming out of them. They were really nothing more than a second muffler. It's the same for single or dual exhaust systems.
Basically it looked like this. Dont pay any mind to the terrible paint drawing  lol
Logged
1hot68
Global Moderator
Old Timer
Offline Offline
« Reply #8 on: April 17, 2008, 05:50:02 PM »
Do you have good exhoust hangers? If they are hard or too ridgid you can get a sound vibration from that too.
Logged
1968 Dodge Charger R/T Clone...493 stroker Tremec 5 Speed And Dana60 3.54Sure-Grip
My Charger is a hybrid car, it burns gas and rubber.
Belgium R/T -68
Full Member
Offline Offline
« Reply #9 on: April 17, 2008, 10:47:39 PM »
Will work on your ideas and come back with results, thanks so far.  2thumbs
Logged
andy74
Old Timer
Offline Offline
« Reply #10 on: April 18, 2008, 02:48:19 PM »
make sure that no part of the exhaust is touching the body or frame,i have seen a lot of cars that have had vibration/resonation issues and that s all it was,a little adjustment!
Logged
1969chargerrtse
Old Timer
Offline Offline
http://www.carsnotforsale.com
WWW
« Reply #11 on: May 03, 2008, 06:05:19 AM »
Here's a picture with the resonator mufflers.
http://www.accurateltd.com/6870%20Hemi%20System.htm
Logged
1969 Charger RT/SE - I remember standing in the Dodge showroom in 1969 drooling over the new Charger.  My parents bought a Chevelle next door at the Chevy dealer.  ( still getting consoling over that )   Wanna trade your car?  My new site:  http://www.CARSNOTFORSALE.com   A big thank you to my wife, for posting for me when I'm not home to do so.  Thanks, honey.
FJMG
Junior Member
Offline Offline
« Reply #12 on: May 03, 2008, 09:13:16 AM »
According to a thread on Dodgeforum.com about mileage in a new Ram, the Resonance theory is bang on. For example, the stock mufflers on the 94-01 Rams have what is called a Humholz resonator and if you replace your factory unit with one that does not have this you will get a drone at approx. 1900 rpm (I'll have to reread the thread to make sure). A fellow going by the name of Hankl on that forum indicated that if you install those mufflers then make sure that your tailpipe length after the muffler is nowhere near 66 inches (for the ram anyway).  This would seem to indicate that the resonance is a function of tailpipe length aft of the muffler. Maybe someone knows if the old dodge resonator is actually A Humholz resonator?
Logged
Belgium R/T -68
Full Member
Offline Offline
« Reply #13 on: July 24, 2008, 02:28:08 PM »
Now I have tried everything without getting anywhere with my problem. I am starting to think moore and moore that the newbuild engine is serious unbalanced
or wrongly balanced. It would fit with the fact that it's very shaky on idle although it's should have been build as a -69 standard 440. You also feel when you drive that
the engine has to work a lot when you push the pedal. Anyone with experience?  icon_smile_question
///Per
Logged
Brock Samson
Old Timer
Offline Offline
Scaring Ricers & Setting off Car Alarms since 1984
« Reply #14 on: July 24, 2008, 03:03:43 PM »
it's a sound or a vibration? couse what comes to my mind (what little is left of it)  eek is a driveshaft vibration which is a cycle kind of drone vibration, i used to have it in the small block and it bugged the crap out of me, but after i got the drive shaft balanced, it completely went away..
 just my  Twocents
Logged
Stratocharger: 1969 Charger R/T Special Edition - Scaring Ricers and Setting off Car Alarms since 1984.
Battlestar Galactica: 1971 Plymouth Road Runner 340 - original.
Sweetheart: Daily Driver 1999 Chrysler 300M P.H.P.
Ice Angel: 1978 Chinook Concours Cherry Class-A 440 Powered Motor Home.
    new Videos check 'em out..
 http://youtube.com/watch?v=rhOfC4FOaeE
 http://youtube.com/watch?v=etvf4wUFzK0
 http://youtube.com/watch?v=cHc0_80IxOo
 http://youtube.com/watch?v=DcsI0sl4qoA
Belgium R/T -68
Full Member
Offline Offline
« Reply #15 on: July 25, 2008, 12:52:11 AM »
 just my  Twocents
Thanks for the input but I forgot to write that you can also hear it sometimes if the car is standing still on idle.
Logged
Belgium R/T -68
Full Member
Offline Offline
« Reply #16 on: July 25, 2008, 11:30:38 PM »
Got some answers back from the previous owner concerning the engine build, it was done by Huntsville engine and should be very good balanced. One thing he did mension
was that he didn't took out the heat-riser flapper valve on the right side and it may be stucked during powdercoating the manifold, could that be an issue although my
problem is according to me on the left side.
//Per
Logged
Mike DC (formerly miked)
Old Timer
Online Online
« Reply #17 on: July 31, 2008, 09:43:09 PM »
This is probably not a popular idea, but I would consider avoiding the secondary mufflers and just switching to a smaller exhaust system entirely.
A 440-inch motor can run a 2.5" dual system pretty well (there will be a bit of power loss, but nothing catastrophic) and the whole exhaust noise will be less.  The larger pipes basically increase the deep bass noise.  Run a smaller system, and you'll keep a lot of the 3" system's characteristic sound but at a lower volume setting.   Or even just neck down the system from 3" to 2.5" after the mufllers before it gets to the tailpipes.
An H-pipe (or X-pipe) crossover is a benefit for a few pounds of torque, but it's also going to decrease the raspy sound too.  Eliminating that is another way to get a bit of a cooler sound from the tailpipes.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.7 | SMF © 2006-2008, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.056 seconds with 15 queries.
