Flexplate
Started by terrible one, May 15, 2008, 02:32:14 PM
terrible one
Where is the best (cheapest) place to get a flexplate? Engine is a '71 383 HP . . .
Lots of them on ebay, just be sure the bolt size and bolt circle matches your converter; a stock 383 HP would use 5/16" bolts and a 10" bolt circle.
http://motors.shop.ebay.com/Parts-Accessories_Car-Truck-Parts-Accessories__dodge-flex-plate_W0QQ_nkwZdodgeQ20flexQ20plateQQ_fxdZ1
Jackson,
440source sells a nice solid disc flexplate that is identical to the B&M sfi (race) plate which is a very strong piece. It is drilled for any converter combination you might come across as well. All of the aftermarket converters come with a 10in bolt pattern and the better ones use larger 7/16 bolts as opposed to the stock converter which uses 5/16 bolts. Either way you're covered with the 440 source plate....and it's a bargain at $29.95  :2thumbs:
http://www.440source.com/flexplates.htm
terrible one
Thanks for the heads up Ron!
I assume the ring/teeth for the Mopars are on the torque converter?
Charger-Bodie
Quote from: terrible one on May 15, 2008, 07:17:44 PM
you-bet-cha!!
