zinc or not necessary
Started by mjwebb, May 07, 2009, 12:55:43 PM
mjwebb
turns out my engine was just rebuilt with hydraulic lifters, roller rockers, etc. so since it's no longer a flat tappet motor can I use any new oil, 10W 40?
Quote from: mjwebb on May 07, 2009, 12:55:43 PM
Are you sure ?  :scratchchin: Hydraulic lifters are available as both a flat tappet and roller design.  :yesnod:
Roller rockers are not the same as roller lifters, I would bet the same as Firefighter and that you still have flat tappet lifters.
mjwebb
ok, thanks....I guess I'll just play it safe and run the Rotella 15W 40 since it is safe for either or
The Rotella formulation has changed, you're pretty much stuck with using an aftermarket zinc additive.
A long thread but stickied for a reason, this is a good read on zinc levels and oil;
http://www.dodgecharger.com/forum/index.php/topic,46015.0.html
