Seattrack studs
Started by Belgium R/T -68, May 08, 2009, 02:16:09 PM
Belgium R/T -68
Where can I find/buy the studs for the -68 seattracks? Mine has no threads anymoore. Worst case is bolts I guess but don't know the dimensions
in inch since I want to use stock nuts.
Back N Black
I used 3/8 carriage bolts from a local hardware store, tack weld them in and works great.
Charger-Bodie
The original studs are 5/16 course. If you want to use the orig style nuts, you will need 5/16 studs.
Back N Black
Quote from: 1hot68 on May 10, 2009, 08:48:01 AM
You are correct, sorry for the wrong bolt size but its been over 2 years, anyhow, i did use the origional nuts.
69*F5*SE
Where can I get the black spacers at?
Charger-Bodie
Quote from: 69*F5*SE on May 10, 2009, 09:52:12 PM
Im sure you can get them at a few places . I got mine from Mega Parts.
Belgium R/T -68
Thanks for the input guys! :2thumbs:
gasoline_24
If you get real carried away you can grind down the carriage bolts so they look just like the factory and tack weld them in.  That is what I did.  Probably overkill, but who cares.
Tilar
It's been so long since I took my seats out that I don't even remember those being on mine. Do they go between the track and the floor?
Dave
Charger-Bodie
Quote from: Tilar on May 11, 2009, 02:04:16 PM
They may not have been there. The studs are long enuf that you can put as many where you need them (as the stud will allow) to make the seat sit the way you feel comfortable with.
Tilar
So they are just there for adjustment?
Dave
Charger-Bodie
Quote from: Tilar on May 11, 2009, 03:15:23 PM
They usually came with them 1 on each stud but Ive seen them with none for that little bit of extra headroom.
