Vega Glass?
Started by Daytona Guy, October 25, 2011, 06:49:44 PM
Daytona Guy
Do they still make the Vega glass. I tride taking the glass out of the hatch to weld in the plug and it exploded on me.
Dane
41husk
I would think most auto glass places probably have the specs to cut a vega glass :scratchchin:
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
Old Moparz
I remember seeing a lot of ads in Hemmings Motor News for vintage glass, & some stated they had glass for any make & model. I suppose I better be really careful with the hatch I have.
A couple of links I found that can offer a quote.....
http://www.restoglass.com/index.html
http://www.sandersreproglass.com/glass.php
               Bob
              Going Nowhere In A Hurry
Aero426
Quote from: 41husk on October 26, 2011, 07:55:21 AM
I don't think the glass is flat.   It has some shape to it.   I think it would be cheaper to source another junkyard hatch versus the glass by itself.
moparstuart
 on my nation wide locator    Moltzans  in great falls MT  shows one for  $31.00
   800-422-8675  worth a try
Nwcharger
picknpull in sherwood has a 74 vega. not sure if its a wagon or hatchback. not to far of a drive. i bought my vega hatch from them a few months ago for 50.00 complete. :2thumbs:
1969 coronet wagon
41husk
I guess I should grab a spare, just in case they get more scarce :scratchchin:
xx29440charger
6PakBee
I have a hatchback from a '72 Vega that I was planning to use.  Now I find out there are two basic versions of the Vega hatchback hatch, '71-'73 and '74-'77. Did I get the right one or is it back to the boneyard?
Aero426
I believe they both fit, but you want the one without the louvers punched in.
moparstuart
Quote from: Aero426 on October 31, 2011, 08:50:10 AM
you can work around the louver and use metal to fill in that area , but yes the  74-77 is a much better option and easier to use
6PakBee
Thanks for the info. :2thumbs:  It's probably a good thing I haven't picked it up yet.  I think they had at least one of the later hatchbacks also.
Daytona Guy
Quote from: Nwcharger on October 26, 2011, 03:06:05 PM
I'm on it. Thanks man
Old Moparz
Quote from: 6PakBee on October 31, 2011, 08:40:14 PM
If they're cheap you should consider getting both.   :Twocents:
               Bob
6PakBee
Quote from: Old Moparz on November 01, 2011, 09:19:39 AM
Does the glass interchange between the two styles?
Old Moparz
Quote from: 6PakBee on November 01, 2011, 08:40:48 PM
I've seen a listing for the Vega hatch window covering '71 to '77, but I'm only going by what I read & have not tried it myself. Don't leave out the other option of the Pontiac Astre hatchback, it's the same hatch as the Vega.
               Bob
6PakBee
xx29440charger
How do you take off the trim from a vega hatch? What is the easiest way to remove it. Your Charger to Daytona expertise is needed! :cheers:
Charger-Bodie
Quote from: xx29440charger on November 03, 2011, 08:22:58 PM
With a w/s mollding clip tool. Its the same as most from that era.
hotrod98
When reinstalling the trim, most guys use the palm of their hand to pop the trim back on. The best way is to use the trim removal tool and pull the clips back and push the trim into place gently and let go of the clip. No chipped paint that way.
Normal is an illusion. What is normal for the spider is chaos for the fly.
Charles Addams
6pkrtse
I just picked up my Vega rear hatch assy local for $40.00. Now just need to get it installed on the car.
1963 Belvedere 413 Max Wedge
1970 Charger R/T S.E. 440 sixpack.
1970 Challenger R/T Drag Radial 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Road Runner 383 4 BBL
1974 Chrysler New Yorker 440 4 BBL
1996 Dodge Ram 2500 V-10 488 cu in.
2004 Dodge Ram 3500 CTD Dually 6x6
2012 Challenger R/T Classic
xx29440charger
What color blue are you going to go Dane?
