DodgeCharger.com Forum
June 02, 2020, 06:26:42 PM *
News: DodgeCharger.com decals are available here!
   Home   Help Calendar Login Register Chat
Pages: 1 ... 67 68 [69] 70 71 72   Go Down
  Print
Author Topic: SRT-8 Daytona Clone  (Read 329906 times)
Chargen69
Old Timer
Offline Offline
« Reply #1700 on: September 10, 2016, 07:26:12 AM »
Woohoo! I'm glad your wait is finally coming to an end.   2thumbs
So does that mean you can insure it as a classic car?
My insurance company State Farm has a Classic Car/ Resto Mod division now and this falls under the latter. So they are going over some of my build pictures to see if we can come to what is known as an "agreed upon value". The premium will be based on that. Guy at work insured his car for $40,000 under a similar scenario and pays about $400 a year. I plan to try for $50,000 which gets me my out of pocket money and about 15%. Trying to get my labor would not be practical as replacement by a pro shop would be between $250,000.00 and $300,000.00 so even if I could get that assessment I wouldn't want to pay that premium.
hagerty!   I had put my 69 on a state farm policy when I got it years ago before restoration.  I had 19,000 in coverage and it cost me $47/month.  last year I switched to hagerty and told them it was worth 50K and the premium is about $40/month
Logged
Old Timer
Offline Offline
Forgotten but not gone
« Reply #1701 on: September 10, 2016, 07:34:28 AM »
Depends on where you are I suppose. I had mine insured with Hagerty and the cost went up more than $100 in a single year. I think my last premium was going to be $429 for $30K coverage. Never again.
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1702 on: September 10, 2016, 11:16:58 AM »
Glad to hear she's been cleared!
 Thanks tsimthae .It was as excruciatingly long as I had anticipated and then some but we are legal so the pressure is off.
iI look forward to seeing it in Alabama now that you will be able to start your 48 state tour!  HAHAHA     2thumbs
I have a few more things to do so it will be a while until I can officially come out to play.
I have started my punch list some of which I have no control.
(1) Sent the drivers window out to California to be re-made. We shall see how long that takes to come back. I still have my lexan mock up window if
     I get to itchy to drive this thing I will try to put that back in.
(2) I told the sad tale of dropping the hood on the car in an act of monumental stupidity. I fixed the damaged area on the top of the fender and
     nose and buffed them out and they look pretty good.
(3) The gas tank being in front of the rear wheels is a long way from my filler on top of the quarter. When I moved it to that location I used 1" ID
     silicone hose to extend the fill tube in through the wheel tub and up to the filler neck. I thought I had enough pitch in it but it holds gas and that
     is no good. That stuff might be good for fuel transfer but gas laying in that actually permeates the tube. I thought I had a leak in the tube but I
     just lifted it up so that it would drain and the overwhelming smell went away immediately. Bottom line is I have to pull out everything in the
     and get in there and fashion a metal line that has the proper pitch or I will blow myself up.
(4) I had opened up the rear wheel openings about 1/2" to allow for more tire clearance but it was not enough on the right side. So I had to work
     on moving the quarter panel out at the bottom without cracking the body work. That seemed to go alright.
(5) Here is a real stinker. I had upholstered my front door panels about 2 years ago. Well the heat in the loft of my shop where I had them safely
     stored was a little too much for the Foam and Fabric glue that I have used a bunch over the years. Must have gotten a bad batch. So I have to
     remove the vinyl from the front door panels, clean off the glue, re-bondo any damage I do to the panel when pulling off the fabric, re-seal them
     and re cover them using commercial vinyl top glue this time. Good times. The more recent work seems to be just fine. Time will tell.
(6) Once all that is done I will take it to a real mechanic to look over the front end and all of the stuff I had to replace to see if I missed anything.
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1703 on: September 10, 2016, 07:28:32 PM »
So here you can see the old set up for the fuel filler extension. The blue silicone hose ended up being back pitched and was holding fuel . Making a hell of a stink in the trunk even though it was not leaking. I replaced the entire thing except the junctions with a 1" steel tube that is heavily pitched to assure the gas drains out of the fill neck.  You know what they say. " Our stuff is nice because we do it twice" yesnod
Logged
Old Timer
Offline Offline
« Reply #1704 on: September 10, 2016, 07:36:36 PM »
Excellent work. I didn't expect anything less.   2thumbs
Logged
Chargen69
Old Timer
Offline Offline
« Reply #1705 on: September 11, 2016, 01:27:06 AM »
mine just renewed for the 2nd year, same price
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1706 on: September 12, 2016, 07:19:41 PM »
So  the insurance company wanted more pictures and asked for one of the engine bay. Can you believe of all the pictures I have posted I did not have one clear shot to send them. So here is the picture I took today.
One of my re do's was the bracing on the back side of the driver side lower quarter panel.  When I took it for a jaunt around the property a couple of weeks ago it showed a tire rub. I cut the welded stob that I had holding the lower panel in place and added an adjuster to move the panel out a little at a time until it looked clear. I then welded the vertical stob back to the frame. I hope this is the cure. I guess I will find out after I jump the car a few times smilielol
As I had mentioned before the front door panels had been covered about 2 years ago and stored up stairs in my shop. The heat must have been too much for the glue that I used. and some of the vinyl was detaching. So I started the process of re doing them. I pulled the vinyl off and removed the old glue. As I expected it pulled some of the bondo away so I had to re mud it and this time I sealed it with K2 Primer.  I got vinyl top  glue so that their would be no letting go. The 3M brand foam and fabric glue that comes in a can just doesn't cut it.
Logged
mike69440
Junior Member
Offline Offline
« Reply #1707 on: September 13, 2016, 07:04:39 AM »
BEST CHASSIS PROTECTION!
http://www.masterseriescoatings.com/index/
Steve,
IMHO this stuff works well, I really would not recommend it if I had any doubts.
I brushed this stuff on the underside of my Terminator 14 years ago and it is still all there, doing its job 78,000 miles later.
03 is a 2-1/2 season daily driver.  I still in many ways regret selling to buy the Cobra.
http://www.dodgecharger.com/forum/index.php/topic,121983.0.html
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1708 on: September 14, 2016, 03:43:04 PM »
Steve,
Looks good. I will have to try that stuff out. At least you were able to find your old car and it is being well cared for. I had a car that I did a custom job on in the early 80's that I had sold to a guy who garage kept it for nearly 30 years. Recently while visiting back home about 5 years ago , I saw the car parked at his son's house under some pine trees and now it is gone. So you are lucky.
Well tomorrow the 15th of September is 4 years to the day that I went to pick up my 68 Charger shell which I had bought pretty much on faith and some scroungy pictures on Craigslist. It was 5 hours away in Georgia.  Today ,one day shy of that anniversary I have plates on the car. They are temporaries until I get my personalized plates in a couple of weeks and the EEK is perfect because I think I made that sound when I got them in hand. So if I wanted to I could take the car for a ride. Will I. Well probably not for a couple of weeks. But there is an excellent reason. Mopar Muscle is sending a photographer around to do a photo shoot which might be in the magazine early next year. So......I can't really take any chances with scratching or otherwise messing it up. I had hoped that they would do it earlier this month but the photographer is coming from Philadelphia and could not justify the 11 hour one way trip to shoot one car. He will now do it on the way to shooting a road course race somewhere south of me.
Logged
cdr
Old Timer
Online Online
Katy,Tx
« Reply #1709 on: September 14, 2016, 03:51:39 PM »
this is GREAT NEWS!!!!!  LOL EEK is appropriate Smiley .
Logged
Swampwing2
Junior Member
Offline Offline
« Reply #1710 on: September 14, 2016, 05:25:25 PM »
I have not chimed in for a while but I have been watching. Beautiful craftsmanship and design. Time to enjoy it for a while, before you get another "idea".   cheers
Logged
71_Charger_R/T
Senior Member
Offline Offline
« Reply #1711 on: September 14, 2016, 09:17:01 PM »
Too bad the license plate wasn't "EEK 6806 What are the real personalized plates going to say?
Logged
Bobs69
Old Timer
Offline Offline
« Reply #1712 on: September 15, 2016, 06:30:13 AM »
After that creation do you have anything left in you?  Are you just warming up?  Or is it business as usual?  I would think that you've given so much of yourself to the build that you'd need a rest!  Artists are usually the sensitive type aren't they?
Or do you find this very taxing?
Logged
XS29L9B2
Old Timer
Offline Offline
dodge charger 440 rt 69
« Reply #1713 on: September 15, 2016, 01:15:42 PM »
very nice
Logged
dodge charger 440 R/T match
WINGIN IT
Old Timer
Offline Offline
« Reply #1714 on: September 15, 2016, 03:03:38 PM »
So Steve, the whole time you planned on finishing the car up on page 69 on this post, didn't you??  icon_smile_big
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1715 on: September 15, 2016, 03:05:43 PM »
That is what I thought when the lady handed me the plate on both counts.
I have plenty of ideas. What I lack is time and money.  Cry  Sound familiar?
Yes. That would have been a good one. The plate I wanted was taken already. That would have said "WARRIOR". So I settled for
"WNGWRIR" . Not as obvious as I would like but better than nothing. (limit of 8 Characters)
I find the work challenging and stimulating as opposed to my day job which many would think is glamorous but is very annoying and boring to say the least. As opposed to sensitive I would characterize myself as "thin skinned". That would be more accurate.
As I stated above I have way more ideas than I have resources (finances) You are only truly free when you are building a car with no commercial expectations. You can only really do that for yourself with your own money. While I would like to say there is another build in the future I can't see what or how that would be in the short term.
very nice
Thanks XS29L9B2. I am watching your project progress nicely. coolgleamA
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1716 on: September 15, 2016, 03:07:08 PM »
Well that is pretty crazy. I did not notice that. So weird.
Logged
WINGIN IT
Old Timer
Offline Offline
« Reply #1717 on: September 16, 2016, 09:41:49 AM »
"Yes. That would have been a good one. The plate I wanted was taken already. That would have said "WARRIOR". So I settled for
"WNGWRIR" . Not as obvious as I would like but better than nothing. (limit of 8 Characters)"
Great minds think alike, I went with a slightly different version.. yesnod icon_smile_big
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1718 on: September 16, 2016, 04:04:01 PM »
Yes. I think I would agree. Yes indeed. yesnod
Logged
Charger_Fan
Old Timer
Offline Offline
Undercover Charger
« Reply #1719 on: September 17, 2016, 04:35:30 PM »
Congrats on finally being able to register it, Steve! cheers
I like your fuel filler tube fix, that looks like it will function much better than the hose.
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1720 on: September 18, 2016, 12:16:56 PM »
Thanks Charger_Fan. I gotta say I am relieved to have replaced it with something more substantial.
Logged
Xenon
Junior Member
Offline Offline
« Reply #1721 on: September 26, 2016, 11:35:43 PM »
Posted on MSN news.................
http://www.msn.com/en-us/autos/enthusiasts/srt8-daytona-clone-is-done-but-nc-won%E2%80%99t-let-him-drive-it/ss-BBwyFvH
Logged
billssuperbird
Old Timer
Offline Offline
« Reply #1722 on: September 27, 2016, 10:30:43 AM »
The car looks Great 2thumbs
Logged
Stevearino
Old Timer
Offline Offline
« Reply #1723 on: October 02, 2016, 05:30:21 PM »
That's kind of crazy. Thanks for the link.
Thanks Billssuperbird.
Here is a little video of the car out on the road for just the second time. The first time I had some air in the coolant system and 5 miles out I spiked the water temp gauge. I bled it off and that seems to have done the trick.
https://www.youtube.com/watch?v=uIkCBnmFDDk
Logged
Hemi Runner
Senior Member
Offline Offline
« Reply #1724 on: October 03, 2016, 03:24:50 PM »
Nothing like going on that first ride in your own creation! Cool video!
Logged
Pages: 1 ... 67 68 [69] 70 71 72   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.079 seconds with 16 queries.
