Modern Bullitt build
BIGBLCK11
Very cool!  I recall it from when you first showed pictures quite awhile ago.   :2thumbs:
keepat
Just starting the restoration and polishing of all of the exterior stainless steel. Fun!
Pat
keepat
darbgnik
Wow, there's a difference!
Brad
WHITE AND RED 69
Looking great Pat! Nice and shiny.  :2thumbs:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
keepat
The original Inland shifter had a mechanical reverse lockout which was disengaged with the T handle. The Tremec 6 speed also has an reverse lockout, but it is operated by a 12v solenoid. So I modified a door jam domelight switch to fit inside and added a top spring to hold tension on the T handle. This will either directly operate the negative side of the solenoid or a relay? I haven't quite decided how I will wire that in yet. I just need to add a slight dogleg bend to the shifter, weld on the 2x1x1/2" mount block and then send it out for Chrome;-)
chargerperson
Looks good.
While not at your level of quality, I also used an original 4 speed shifter for my 67 charger when I had a T-56 installed.  Interior of the car looks original (is original) while the transmission, motor, etc. are modern
keepat
I'm using the American Autowire classic update series harness. Very nice harness as it uses all of the original connectors. None of the ends are installed so you can adjust the length of the wires as you see fit, along with having all of the additional wires needed for a modern car such as electric fan, electric fuel pump, door locks, power seats and power windows. It looks original with the same color code, but with one nice addition all of the wires are labeled every 4 inches. Instrument panel worked out great!
A few modifications along with a couple brackets I made to hold the new fuse box securely, with access from the glove box.
Need to paint the gray plastic face plate black to finish it off.
Pat
Derwud
Doing the American Autowire on my 70 and LOVE it!!! Good Crimpers are key, but love it..
1970 Dodge Charger R/T.. Owned since 1981
Very nice. Are you adding wiper delay? Any changes like converting to volt gauge or extra capacity alternator?
keepat
Quote from: Derwud on January 02, 2019, 10:16:16 AM
American Autowire makes a great harness, this is the 2nd car I have used their classic upgrade series. 1st car was my Son's 68 Bullitt mustang. I like how all the connectors are factory type crimps with the right tool!
keepat
Quote from: b5blue on January 02, 2019, 11:15:30 AM
I did convert the amp gauge to volts, but no wiper delay as I'm sure the only rain I'll get caught in is a monsoon ;-)
Pat
Derwud
Quote from: keepat on January 02, 2019, 01:52:23 PM
I knew I should have ordered that for my Brothers 67 Mustang Fastback.. Ordered a stock replacement from some guy in New York..
mopar4don
Pat, Awesome job as usual!   :yesnod:
So the classic update series does the entire car?
Derwud
Quote from: mopar4don on January 03, 2019, 12:17:21 PM
Yes. it is very complete..
keepat
Quote from: Derwud on January 03, 2019, 12:36:10 PM
What Derwin said, but you should buy their crimp tools.
Thanks!
Pat
Derwud
Quote from: keepat on January 03, 2019, 05:24:45 PM
Thanks!
Pat
Yes..... x2 to getting a good set of crimpers..
TexasStroker
I had assumed the AAW box would hit the hinge and had thus planned to build a hinged, drop down bracket under the dash.
Might have to steal your setup instead...looks great!
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
alfaitalia
Fantastic work as always Keepat.....how do you fancy popping across to England to help me with mine!!! LOL!
Fonzy
Always a pleasure checking your thread. Love the time and care you put into this project  :2thumbs:
keepat
Quote from: TexasStroker on January 14, 2019, 03:19:31 AM
The plastic glove box helps make it work much better than the factory cardboard glove box.
Quote from: alfaitalia on January 14, 2019, 08:37:19 AM
I'm sure if you're covering the first class airfare we could work something out ;-)
Thanks!
Quote from: Fonzy on January 15, 2019, 11:51:14 AM
Thank you!
Pat
MxRacer855
XH29N0G
I keep reading and enjoying this thread even if I don't send thanks regularly - you should know I deeply appreciate it and really like the combination of quality work with clever engineering and fabricating solutions.
Or maybe it protects us.
