69 Taillight housing
Started by comet_666, July 07, 2014, 05:30:02 PM
comet_666
Anyone know what nuts hold these in? Also was it standard procedure to use black rtv or whatever all over the gaskets?
WHITE AND RED 69
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
twodko
The OEM gaskets on my car had no adhesive. When we finished our restoration I just used new gaskets
.........same same with the lens to housing connection. Just new gaskets. Also don't
crank the fasteners down too hard.
comet_666
Yah wow exactly!
I may just find nuts/washers to fit.
Thoughts on the goop all over these housings?
comet_666
Or how to get the lenses to shine up again?
nvrbdn
 :scratchchin: i wonder if the new headlight polishing kit would polish up that plastic?  :scratchchin:
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
twodko
First thing to do is run them through a wash cycle in your dish washer BUT NOT THE DRY CYCLE.
I think one of the HL polishing kits would work but the dig would be getting into the deepest parts
of the lens. Maybe a Dremel tool with some kinda buffing wheel thingy might work.  :shruggy:
gtx6970
IMO< the correct nut is
It's the only nut  I've seen on several cars I've looked at on on the car I just finished
avail at
http://amkproducts.com/bulk3.asp?part=B%2D13877
comet_666
Min order is $30.00 lol
Guess I could poke around that site a bit to see if I need anything else but I think it's the worst website ever devised by man.
Thanks for the tip!!!
jaak
Quote from: comet_666 on July 10, 2014, 12:13:46 PM
I know this sounds crazy, but I read it online, and did it with my lens. Use toothpaste to polish them. I cleaned them up real good with soap and water, then polished them by hand with toothpaste (I actually used a toothbrush on the ribbed portion). They turned out great, nice and shiny and after a couple of years of use, still look as good as the day I finished them up.
Jason
comet_666
Was just thinking about cleaning them yesterday...ill try the tooth polish and see if it works!!  Thanks for the tip!
I've use the Meguiars plastic cleaner and polish with good results but toothpaste does work, I've done it in the past.
comet_666
I used toothpaste and it removed quite a bit of the easy stuff, then I switched to 1500 grit wet sand and then washed and put a bit of armor all on them.
Worked out great, 90% of the pits and scraped and whatever else came right off!
Now, I just need the chrome trim... :'(
comet_666
Here are a few pics
comet_666
An another
