Ignition wires
Started by TonyN, August 11, 2014, 06:54:33 PM
TonyN
I don't know the age of the wires, nor of the electrical tape wrapped around a couple of them, and am looking to replace.
It is a 1971 440 engine. Are there brands I should look for, or avoid? Is it like some fancy video cables, that you can really overpay for no benefit?
Thanks,
Tony
Hard Charger
hear good things about firecore brand wires.
Al
1968 Dodge Charger, 383, UU1
Msd on mine. 50 ohm/ft. Moroso ultra 40's arr good too. Ive never run the firecore but have yet to hear a complaint.
Firecore makes the best fitting, highest quality wire set available....bar none. The Firecores are configured specificly for each application and use premium double crimped brass terminals and silicone boots.  :2thumbs:
There are 2 sets available :
(1) Factory fit for stock manifold exhaust and routed identical to the OEM wires using the stock wire looms
(2) Pro fit for header exhaust
