Fun math problem
Started by 69 OUR/TEA, February 14, 2017, 02:44:19 PM
69 OUR/TEA
Here is a math problem that will be fun to see the various answers given . Just give your answer , don't explain how you arrived at it , just your answer to see what most come up with .
birdsandbees
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
BLK 68 R/T
RECHRGD
13.53 @ 105.32
timmycharger
Ponch ®
"I spent most of my money on cars, birds, and booze. The rest I squandered." - George Best
Chrysler Performance West
CRW-FK5
68X426
10 and 14, both are correct.  14 is more correct.
You did not provide sufficient or complete algerbraic expressions on the final line, so both can be correct.
Hope you don't work on dam inspections here in Northern California.
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
there is only one answer, which is 10
the rule of math is that multiplication & division is done before addition & subtaction
XH29N0G
There is an accepted order of operations (PEMDAS) that gives 10 (ditto the post above).  14 would follow some other rule.  I do not see the 28 (please explain), but I suppose in base 9, it would be 11. I cannot figure out if there is some other answer that has escaped us all.
Sorry,  Did not see the please don't post how you got the answer until after I did this one and the next one.  (Guess you should also have reading test.)
Or maybe it protects us.
ws23rt
alfaitalia
I would like to see the explanation of how to get to 10 when 14 seems clearly (to me at least) the only possible logical answer...as a screwdriver is 1, pliers is three and a drill is two. Four screwdrivers (4x1=4) plus pliers (3) times drill (2) is clearly 14??????
XH29N0G
I think the 10 comes from multiply first (3*2) then add 4 from the order of operations rule.   14 would be following another order of operations rule that I have not seen, but may be there.   I still cannot figure out the 28.
Sorry,  Did not see the please don't post how you got the answer until after I did this one and the last one.  (Guess you should also have reading test.)
69 OUR/TEA
Quote from: alfaitalia on February 14, 2017, 05:17:54 PM
Please Excuse My Dear Aunt Sally   ( PEMDAS) , order of operations .
alfaitalia
Quote from: XH29N0G on February 14, 2017, 05:25:08 PM
Really? Must be US thing!...over here if you wanted the multiplication done first....it would have to be first in the line from the left.......pretty obvious really imo.
69 OUR/TEA
PEMDAS is an acronym for the words Parenthesis Exponents Multiplication Division Addition Subtraction. For any expression, all exponents should be simplified first, followed by multiplication and division from left to right and finally addition and subtraction from left to right
funknut
69 OUR/TEA
O.K , since you've solved that one ........
alfaitalia
1.....unless you have some other shady maths rule over there!!! :lol:
 hmmm  :think: ,  I've come up with 13 or 12  for the second one  !    :shruggy:  :P   not even sure 14 was right on the first one  now  :lol:  , unless the first  answer should of been a hammer !!  thinking if a selection of four screwdrivers  ,  pliers & a drill don't work  , use a hammer    :P  i'm going to wait for my bus  :cryin: :shortbus:  ;D
birdsandbees
Since only the last line is solvable..  2
..and Alf, maybe check with your grade 3 teacher on the rules of math.  :pity:
timmycharger
Quote from: XH29N0G on February 14, 2017, 04:43:13 PM
I see what I did.  I had the value of the drill as 4 vs 2.
XH29N0G
20?  unless I cannot count and it is
5
5
2=2
I was wondering what the first one would be if the third line was a 0 e.g. the screw driver also equaled 2?  would it be 2^4+6 or 2*4+6?????  The drills work as 2+2 or 2^2.
flyinlow
10
and 12 for the second ,Assuming you keep adding as you drop from one line to the next........what happens when you assume?
