Fun math problem
Started by 69 OUR/TEA, February 14, 2017, 02:44:19 PM
flyinlow
top view  is the same as the front. so the object is a cube.
It is a cube with a hole turning 90* encased in it, or it is a cube with a tee shaped hole encased in it or it is a cube with two or three holes bored thru intersecting at the center.
So the view is a square or the same view you have shown as the top.
In the words of Mr. Spook, "insufficient data" to decide between the two choices.
ws23rt
Quote from: XH29N0G on February 20, 2017, 04:44:45 PM
Now I feel completely lost. I suppose it could be something like this, but I do not know how the third dimension is represented.
PS.  This should be my #1970 post...
If you project a top view of your (side view drawing) -- the circle will be below center. ---And a front view will show it to be above center.  :scratchchin:
Sorry I miss spoke a bit above and fixed it. :shruggy:
Also maybe my mentioning 3D was misleading.  It was not intentional.   I just ment to say that this can be fabricated (in 3D :shruggy:) with dimentions added for size.
The third view (the question) just shows the missing information needed.
ws23rt
Quote from: flyinlow on February 20, 2017, 05:11:08 PM
There is enough data here.   In your proposals hidden lines would identify just where holes start and end in the top and front views.
As far as I know their is only one answer.
XH29N0G
Or maybe it protects us.
ws23rt
XH29N0G
Weird.  I would not have gotten there if you hadn't pointed out the high low thing.
Now I have a 1970 charger and am on post 1972  :icon_smile_big:
flyinlow
possible solution
flyinlow
The sphere and the curve of the modified prism would be tangential and only share one molecule. Therefore you want to use a very strong material such as solid Neutronium  (Star Trek the original series)
In the last view , if the the object was oriented with the arrow pointing toward a very strong source of gravity, say near a singularity in the range of lets say 10,000 G's The sphere and the prism could be separate ,just held in position by the high coefficient of friction from 10,000 G's
I think.   :shruggy:
Mytur Binsdirti
Try figuring out math problems the new common core way....
https://www.youtube.com/watch?v=2YMbKh9a0Sk
timmycharger
Quote from: Mytur Binsdirti on March 02, 2017, 01:09:05 PM
HAHAHA perfect Mark!
It is pretty bad that I need to check with a friend who was a math major in college to help me help my kids with their homework..  F that!!
If they'd continued the number line to the left, it would have been easy to solve.
And yes, it's a dumb way to have to do math homework.
XH29N0G
I remember getting lectured about doing math the wrong way, and that was in the 1970's...........
DeltaV
Ma and Pa Kettle are turning in their graves.
Don't fight a battle if you don't gain anything by winning. - Erwin Rommel
